Alienware 17 R1 No Power No Light On Power Button
Discussion in 'Alienware 17 and M17x' started by Baqir, Mar 31, 2020.
Tags:
  1. Baqir
    Baqir Notebook Consultant
    Hello,again everyone i know i have posted alot of problem. I was changing power button cable and keyboard cable then i tried turning on laptop its not working i have chekced multiple times the wires are connected properly and power jack seems fine after testing so what could be the problem.
  2. senso
    senso Notebook Deity
    Was it working before you changed both cables?
  3. Baqir
    Yes it was i tried with old cables it doesn't work now
  4. senso
    Did you do the replacement of parts with the battery removed and no charger connected to the laptop?
    Have you already removed the CMOS battery, laptop battery and charger and let it sit a bit and then try to power it up using AC only?
  5. Baqir
    Actually i don't have a battery of course i removed everything else but don't know what happened there.
  6. senso
    Can you post photos?
    Maybe something not well seated, or upside down.
  7. Baqir
    It gave power for 5 seconds then it went off.
  8. Maxware79
    Maxware79 Notebook Evangelist
    5 Beeps is the CMOS battery. Just make sure that it's seated properly. Sometimes just restarting it a few times will get rid of this error.
  9. Baqir
    I don't have 5 beeps it doesn't start after pressing power button.
  10. Maxware79
    Oh sorry, I read it wrong.
    It's possible that you damaged the ribbon cables. They are quite fragile so take them out and check the ends that go into the connectors. If any of the gold tips are damaged then it could be causing your issue
