alienware 17 r1 (2014) 970m problem
Discussion in 'Alienware' started by Xguarded, Jan 26, 2021.
  1. Xguarded
    Xguarded Notebook Enthusiast
    hello guis!
    Ive recently baught a alienware 17 R1 (2014 ) with a dead ati r290x. so ive baught a 970m and installed it. the bios sees the card and so does windows. Windows shows error 43, but when i disable and enable it shows no error. When i open gpuz it shows some missing fields. Also nvidea control panel cant be opend.
    is the card dead or does it need a different vbios ?
  2. Tenoroon
    Tenoroon Notebook Consultant
    In your case, the card is most likely dead. I've had desktop GPU's do the same thing, code 43, and missing fields in GPU-Z. Though, I would try re-flashing the vBIOS as that may also be the issue. If a vBIOS flash doesn't work, the card is dead and you will need to contact the seller ASAP.
  3. Xguarded
    Thanks for ur respond! This is exactly what i taught. Ive tried reflashing this morning and the flash was successful but gpuz stil shows the same... i just contacted the seller hope he wil accept the return!
  4. Tenoroon
    Alright, if you have any more questions, let me know!
  5. Baqir
    Baqir Notebook Consultant
    did you disable secure boot and fast-boot also can you confirm that if you are in UEFI.
  6. Xguarded
    yeah its all in uefi, fast boot was diabled and also secured boot.
    ive returned the card and put in a m4000m wich works perfect ( instal with driver signature turned off )
