Alienware 15r3 7820hk heat issues
Discussion in '2015+ Alienware 13 / 15 / 17' started by EepoSaurus, Mar 3, 2018.
  1. GreatD
    GreatD Notebook Consultant
    @c69k Where can I get foam barriers? Aliexpress??
  2. c69k
    c69k Notebook Evangelist
    Mr. Fox and Vasudev like this.
  3. Vasudev
    Vasudev Notebook Prophet
    Falkentyne and c69k like this.
  4. Mr. Fox
    You can use a number of things to make a dam or barrier to keep liquid metal from escaping from where you place it. Foam dams are one example, as shown the the video in my YouTube channel. If you use foam, it needs to be very thin to start with. It should not be much thicker than the air space you will fill with it. It should also be super soft and compressible to near zero height with little or no resistance. Otherwise, it can interfere with heat sink contact. I used a thin layer of foam that came in shipping material to protect an LCD panel. (That is what is visible in the video.)
    You can also use a thick non-conductive thermal paste, or a narrow bead of RTV silicon. If you use RTV silicon, lay some tape or thin layer of plastic wrap on top of the bead of silicon to avoid having it glue the heat sink in place. The next time you take it apart, it won't be stuck and you can throw the plastic away. The bead of silicon should continue working as a gasket after removing the plastic.
    Papusan, Vasudev and Falkentyne like this.
  5. mokobey
    mokobey Newbie
    how did the foam stay in place?
  6. electrosoft
    electrosoft Tick Tock Clarice....
    By the compression of the CPU/GPU heatsink collapsing it and holding it in place. That is why the thicker but with a high compression rate is better to
    use. Just make sure the foam doesn't impede the pairing in any way.
  7. pathfindercod
    pathfindercod Notebook Deity
    Is there a good source for this foam?
  8. mokobey
    mokobey Newbie
    thanks. can kitchen sponge type work? but I can cut it thin and flat
  9. Usama
    Usama Newbie
    Hey guys, I'm new here despite reading the forums for years. I recently just bought a 15r3 with the i7 7820hk and gtx 1080mq too like the op for a decent $2400 CAD (only reason i bought it). Anyways i overclocked it to 4.5ghz and hit 91°C max on it....before settling around 89°C running cinebench 8-10 times. Now I may have jumped the gun and worried too quickly and ordered an exchange model but where these temps getting too hot with my overclock? What should i be achieving or aiming for regarding temps? Srry if i broke any newbie rules but I just want your opinions.
