Alienware 15 R3 - Heat Analysis - Urgent Help
Discussion in '2015+ Alienware 13 / 15 / 17' started by Carefree Engineer, Aug 4, 2017.
  1. Vasudev
    Vasudev Notebook Prophet
    Don't buy MAX Q GPUs for gaming, you need to OC more to get 1080 non MAX Q like performance.
  2. Carefree Engineer
    Carefree Engineer Notebook Enthusiast
    But 1080 MaxQ will give performance more or similar to 1070 right?
  3. Vasudev
    You could have got MSI or ASUS w/ 1070 at a lower prices.
  4. Carefree Engineer
    I really wanted to get asus 502vs but here in uae its a bit expensive and coming with UHd 4k display only but I need a FHD display. Whats your feedback on acer predator G9?
  5. Vasudev
    Skylake or Kabylake?
  6. Carefree Engineer
    KabyLake. 7700HQ with 1070
  7. Vasudev
    Are you satisfied with 7700HQ CPU? If so, check the price if it is lower than 15 r3, then go for it.
  8. Carefree Engineer
    Yes I am totally fine with it. My primary concern is that temp should not exceed 90 even under heavy gaming. Which laptop you recommend which is super cool except sager and clevo?
  9. Vasudev
    That I cannot promise. Because the CPU temps are directly proportional to your ambient temps. So increase in ambient temps will cause the temps to reach 90C or even higher under full load. But, if you manage to keep your under 30C it will max out 85C both on cpu and GPU.
  10. Robin668
    Robin668 Notebook Enthusiast
