Alienware 15 and 17 melting DC In cable
Discussion in 'Alienware' started by Dangerous_Dave, Jun 24, 2018.
  1. Dangerous_Dave
    Dangerous_Dave Notebook Guru
    I had an Alienware 17 R2 a few weeks ago that I had to return because the cable that runs inside the machine from the power jack to the motherboard had previously melted and been replaced, with the result that the bottom case plastic that sits directly below it was also partially melted (the seller didn't mention this until I got it). Last week, I bought an Alienware 15 R2, and when that turned up, I noticed the same localised blistering on the lower case plastics, and when I opened it up, sure enough, the DC cable looks like it has been very hot, and the plug where it goes into the motherboard has discolouration and maybe partially melted.
    So now I'm thinking this is a design fault with this generation of Alienware laptops. I've done some googling around, and other people have definitely had this issue, so I'm surprised it isn't being officially called a design fault. I'm wondering if anyone here has one of these laptops and has experienced the same thing?
  2. TheReciever
    TheReciever D! For Dragon!
    Yep, quite a few have experience similar issues.
    Especially around the point the battery connection also fails iirc
  3. Dangerous_Dave
    Have Dell acknowledged it/will they do anything about it? The machine is not within warranty any more, but this is surely a result of poor design.
  4. TheReciever
    I wouldnt know personally, the machine isnt within my preference due to BGA but I would look up the clubs and see what your options are.
    As for dell admitting design fault, I doubt it.
  5. Papusan
    rinneh likes this.
  6. rinneh
    rinneh Notebook Prophet
    Its a very strange issue. According to Alienware the later bioses should prevent htis issue. It is because a too high power draw from the PSU. But the margins seems to be quite thin. I recommend using the latest bios and replace the cable and in theory it should be good as long if you dont overclock.
    I ran my AW15R2 for for 2 years without issues but as soon as I started to OC my GPU it came back unfortuantely but got my laptop replaced. But for that you need to have the laptop in your name I suppose and have some warranty left. If you are in NL or near NL I can send you a cable that I have new for shipping costs only.
    Dangerous_Dave and Papusan like this.
  7. Dangerous_Dave
    Would love to get hold of that cable. I'm in the UK. Can I PM you?
  8. rinneh
    Yeah sure. I am currently not in NL though. WIll be back in 2 weeks.
  9. VoodooBane
    VoodooBane Notebook Consultant
    I am a little late but There was a bios update for that a while ago... the other fix that works if turn off fast charge, change it to standard charge. Acetate coth tape would help a lot as well with keep the wire insulation from melting... it deflects out side heat. Of course buy a new power jack cable first .
  10. juggar
    juggar Notebook Consultant
    I saw this issue on an AW 17 R3. Had to replace cable (cheap) and then the battery promptly failed a day after. Im sure it was related. Battery was like $71 for a new OEM one.
    Replacing the cable isnt all that bad but it does require some very extensive disassembly.This is one scenario where an extended warranty would have saved a lot of people a headache. I dont know of any motherboards that have been rendered unusable yet so it should be reparable.
