Alienware 14 R1 Ribbon Cable for Keyboard/Touchpad
Discussion in 'Want to Buy Forum' started by Dr. AMK, Sep 3, 2017.
Tags:
  1. Dr. AMK
    Dr. AMK Notebook Evangelist
  2. Snodge
    Snodge Notebook Consultant
  3. Dr. AMK
    Thank you for your kindness,
    14 r1 not m14x
  4. Snodge
    Ah sorry I'll have a closer look
  5. Dr. AMK
    Can anyone help?
  6. danyune
    danyune Notebook Evangelist
    I wonder if any other alienware makes the same size, like
    http://www.ebay.com/itm/NEW-Alienwa...727664?hash=item3aaa726830:g:jVkAAOSwrklVSwFD
    Ribbons aren't anything special, just link pin to pin to the components. If you can find one with the same width and long enough (I think above would be too short), then you might have a chance (The link above has the same # on it as the one you linked in OP)
    But maybe something like one of these might fit:
    http://www.ebay.com/itm/Alienware-1...648011&hash=item4b23c4b25a:g:q9oAAOSwSKlZbh5d
    http://www.ebay.com/itm/Alienware-1...928317?hash=item3ae9d18fbd:g:A3MAAOSwIjJZQeaS
    Any good luck dude
    Dr. AMK likes this.
  7. Dr. AMK
    Thank you for your kind support, I'll try doing your advice and find the pins number cable even from different models. The problem is how to know the number of pins :)
    Regards.
  8. Dr. AMK
    This is a reply from www.parts-people.com:
    "this cable appears to be specific to the Alienware 14 R1 model and we do not have any compatible replacements or any sources for this part."
    Is there is anyway to fix the cable, by rebuilding any damaged lines or something?
