Alienware 14 cpu running at 0.799Ghz for all four core
Discussion in 'Alienware 14 and M14x' started by learningME, Jul 12, 2018.
  1. learningME
    learningME Notebook Enthusiast
    cpu suddenly not working well today , 2 day ago its was running at 2.4Ghz and above
    i can play csgo and overwatch at low setting quite smoothly.
    i did repaste twice , but didnt update the bios before do not know if that is the problem .
    Do anyone know how to solve thing problem , and make it run back to its full speed?
    thank you in advance :]
  2. EepoSaurus
    EepoSaurus Notebook Evangelist
    Is your power supply plugged in or are you running on battery? Go into your power options and set it to high performance and find windows mobility center and do the same. Lastly if all that is the same you may be having an issue with your power supply.
  3. learningME
    i went power options and windows mobility center set it to high performance for two hour its is running fine at 3.2ghz after the two hour it when back to 799 mhz even in game
