Alienware 13 r3 with OLED 2k display or 15 r3 with 120hz display
Discussion in 'What Notebook Should I Buy?' started by Chintu7107, Feb 24, 2017.
  1. Chintu7107
    Chintu7107 Newbie
    I am having trouble deciding on 2 maxed out laptops from alienware.
    Alienware 13 r3
    touchscreen 2k OLED display
    32gb ddr4 ram
    2 tb pcie ssd
    vs
    Alienware 15 r3
    120hz display
    32 gb ddr4 ram
    1 tb ssd pcie, 1 tb 7200rpm hdd
    I want a laptop that can last me years and can be good for high school and
    medium to heavy loads of gaming. I also want to know which screen would be the most durable.
    When I talked to people at Alienware they told me that you can upgrade the gpu and cpu of the next generation only if the power supply supports it. I love the alienware 13 because of its oled display and it's touch screen ability. But I am used to having a 15 inch mac book pro.
    Tell me which screen is better out of the two
    How long they can each last without any damage
    which screen is most likely to live a long life
    My requirements:
    Laptop must have 1070 if 15 inch or 1060 if 13 inch
    Laptop should last me up to 6 years or more
    Which screen is better ? OLED 2K OR 120HZ DISPLAY?
    I AM GOING TO USE THE LAPTOP FOR MEDIUM LOADS OF GAMING, SCHOOL AND CODING
    WHICH ONE IS THE BEST OPTION?
