Alienware 13 R3 lights won't come on
Discussion in '2015+ Alienware 13 / 15 / 17' started by madferret9, Dec 31, 2016.
  1. madferret9
    madferret9 Notebook Enthusiast
    Honestly I'm almost at my breaking point with this comptuer. It has literally been problem after problem. Now it's the backlight on the keyboard. None of the lights come on and the AlienwareFX software is set to Light mode. When I press Go Dark and then press Go Light, all the lights fade up to 100% brightness then turn off immediately. None of the lights are on- the power button, keyboard, logo, etc. I've had this happen a few times now. I tried restarting the computer, etc.
  2. Xenrail
    Xenrail Notebook Consultant
    Exchange it
  3. theburnination
    theburnination Newbie
    Slide the brightness slider. I had the same issue. I clicked brightness down a notch and lights worked fine. You can access it by right clicking the alien head in the system tray.
    Ynglaur likes this.
  4. SimplyJ3sse
    SimplyJ3sse Notebook Consultant
    My original would periodically stop working and either reinstalling command center is reflashing the bios would fix it temporarily. My replacement has yet to have any lighting issues not fixed by a reboot.
    Sent from my VS995 using Tapatalk
