Alienware 13 R3 GTX 1060 OLED VBIOS modification?
Discussion in '2015+ Alienware 13 / 15 / 17' started by hans12321, Nov 2, 2017.
  1. hans12321
    hans12321 Notebook Consultant
    I will try my best ;) don't wanna breake my little alien
  2. Sentential
    Sentential Notebook Consultant
    Considered doing this as well, it'll be interesting to see your results, mine I planned on doing the opposite and going more of a Max-Q route.
  3. hans12321
    Unfortunately i can´t get any vbios provided by Coolane to work in my Alien..
    @Sentential do you already have a hardware programmer ?
    Are you willing to try the vbios on yours?
  4. hans12321
    I'm currently flashing the newest vbios from @Coolane
    Hopefully this will work..[​IMG][​IMG][​IMG]
    Gesendet von meinem SM-G950F mit Tapatalk
    c69k, Vistar Shook and Coolane like this.
  5. hans12321
    Recently i got it to work now!!
    Did the wrong reinstall with ddu... i'm stupid
    [​IMG][​IMG][​IMG]
    c69k and ThatOldGuy like this.
  6. Sentential
    No I don't have a hardware programmer I was either going to use a dumped BIOS from another MQ vendor and use pascal flasher or similar to force flash mine into a 1060-MQ
    pathfindercod likes this.
  7. hans12321
    unfortunately it is not possible to flash pascal cards with modded vbioses these days...
    You need to use a hardware programmer. @Sentential
    ThatOldGuy likes this.
  8. ThatOldGuy
    ThatOldGuy Notebook Virtuoso
    Wait, why?
    Just underclock in MSI Afterburner. Of put FPS cap if you wan't better thermals/noise level
  9. hans12321
    c69k, Coolane, leeloyd and 1 other person like this.
  10. leeloyd
    leeloyd Notebook Consultant
    @hans12321 Glad you finally succeeded ! Gratz ;)
    I see that you hardflashed the UG15 labelled chip for your AW 13R3.
    As i told you, i hard flashed the UG13 one on my AW 15R3.
    UG13's and UG15's label locations are swapped between our motherboard.
    Looks like the good one is the lowest located on both mobo.
    I wonder if those chips aren't both VBios chip with a backup one... or maybe are mux/demux related.
    c69k and hans12321 like this.
