Alienware 13 R2 and 15 R2 with AGA
Discussion in '2015+ Alienware 13 / 15 / 17' started by n0ob, Feb 16, 2016.
  1. n0ob
    n0ob Notebook Enthusiast
    finally got both my laptops some AGA time, and just thought i'd share my findings.
    here are the specs for each:
    13 R2: core i7 6500u, GTX 960M 2GB, 16GB DDR3L GSkill Ripjaw 2133mhz ram (running at around 1600mhz)
    15 R2: core i7 6820HK, GTX 980M 8GB, 16 GB DDR4 2133 ram
    AGA: EVGA GTX 980 Ti Hybrid
    the only benchmark tool i have is 3D Mark
    what i've learned
    using the graphics amplifier with the 13 R2 (http://www.3dmark.com/fs/7575623) , i'm getting a little higher performance than a 15 R2 using its 980M (http://www.3dmark.com/fs/7461769).
    as far as bottle necks are concerned, the i7 6500u is such a significant bottleneck. granted, the graphics amplifier significantly increased the graphics performance of the 13 R2 from its 960M graphics card, im not sure its even worth investing in a 980 Ti in a graphics amplifier if the performance will still be degraded by the processor. sure these are just the firestrike scores and this is a synthetic benchmark, but I've gotten the same results through Heaven and Valley.
    Just something to consider to anyone who's thinking about their setup.
    13 R2 using the 960M: http://www.3dmark.com/fs/7485365
    13 R2 using the 980Ti: http://www.3dmark.com/fs/7575623
    15 R2 using the 980M: http://www.3dmark.com/fs/7461769
    15 R2 using the 980Ti: http://www.3dmark.com/fs/7553902
    no overclocks were applied to the 980 Ti in all tests, the 15 R2 was using OC LVL1 from the BIOS Performance options.
    hope this helps anyone who's on the fence about which system and what setup to go with.
  2. A-leo
    A-leo Notebook Guru
    aga definitely limited by cpu thats why you should get the quad core chip non u cpu.
    the bandwith itself isnt problem just point out that graphic score
  3. pathfindercod
    pathfindercod Notebook Deity
    I think the 13 with GA sweet spot is a 970 for price to performance with the cpu limitations.
  4. n0ob
    honestly, i knew there would be a degradation in performance, but wasn't expecting it to be that much.
    A-leo likes this.
  5. Game7a1
    Game7a1 ?
    Question. Were you not able to get the RAM to run at 2133 MHz? Even when trying to modify the RAM settings in the BIOS?
  6. n0ob
    i tried, but often times, the thing just beeps at me and breaks my setup. i'd have to take off the stick of ram so it can re-discover it.
    in the bios, it cant even read the speed properly (it shows 0)
    what i am noticing is that instead of running the ram at 2133, it runs it in low latency (9-9-9-28)
  7. Scrapple Joe
    Scrapple Joe Notebook Enthusiast
    next gen mobile chipset from Nvidia with 8gb will basically be able to pull off VR without the amp..
    good to know
