AlienFX for WMP/iTunes is Awesome!
Discussion in 'Alienware 18 and M18x' started by skygunner27, Jun 30, 2011.
  1. skygunner27
    skygunner27 A Genuine Child of Zion
    Thanks.
    Unless some one writes a plugin we're out of look outside of WMP & iTunes. We have 2 M18x's. Only difference is one has a 2920XM and the other has a 2960XM. Maybe I'll make a AlienFX video in HD with both M18x's playing the same song. :)
  2. Ferrari353
    Ferrari353 Notebook Evangelist
    What about morphing? Would it be possible to do that without too much effort?
    Sent from my SGS2 Skyrocket using Tapatalk
  3. skygunner27
    AlienFX does have an advanced set of features that includes morphing. It just doesn't do it very well. We are lucky that Dell/compaq took the time to include the AlienFX plugin for the M18x, M14x & R3.
  4. Ferrari353
    I couldn't find said feature. How do I set it up? Also what should the music setting thing be set to. The one that deals with Hz ranges or w/e
  5. Ferrari353
    What you're looking for is the Optimus Maximus keyboard. Each of the 113 keys is its own little screen. The letters change when you press shift or turn on caps lock, and when you enter a program like say, Photoshop, it can be set to make each key show the shortcut that that key performs. If only it was cheaper or I was a millionaire...I wonder if anybody would actually be stupid enough to spend $1800 on a keyboard...
  6. J_deezy85
    J_deezy85 Newbie
    So glad I saw this post. saves me from downloading a winamp and plugin for it :)
  7. reaversedge
    reaversedge Notebook Evangelist
    is the fx timing on the itunes same as the one in wmp? wmp is already awesome but if there is some distinction between the two in terms of musical timing then i might give itunes a try also.
  8. Ferrari353
    I feel like there is a difference but I'm not 100% sure. In iTunes, it seemed laggy so I switched to wmp, but it still seemed laggy (but it felt less laggy) so I'm not sure. I think it just seemed laggy because I listen to mostly dubstep/ electronic and it doesn't change colors for a lot of the sounds.
  9. skygunner27
    bump bump bump for all you new members/owners:)
  10. ryoujikaji
    ryoujikaji Notebook Enthusiast
    This rocks!
    ____________________
    Alienware m18x | Nebula Red | Intel® Core™ i7 2760QM 2.4GHz | 4GB Dual Channel DDR3 at 1600MHz | 18.4-inch WideFHD 1920 x 1080 WLED | Dual 2GB GDDR5 AMD Radeon HD 6990M AMD CrossFireX | 1.5TB RAID 0 (2x 750GB) 7200RPM SATA 3Gb/s | Windows® 7 Home Premium, 64bit | Slot-Load Dual Layer DVD Burner | Internal High-Definition 5.1 Surround Sound Audio | Intel® Centrino Ultimate-N 6300 a/b/g/n 3x3 MIMO Technology and Bluetooth 3.0
Similar Threads - AlienFX iTunes Awesome
  1. gpc
    10
    423
