Alien FX problems
Discussion in 'Alienware M15x' started by faelken, Jun 12, 2010.
  1. faelken
    faelken Notebook Enthusiast
    I have been using my new M15x for a week now and I realize that the color for zone 1 &2 (the alienhead on the back and above the keyboard) updates much slower than the other zones which update immediately. Sometimes I have to change the colors back and forth for the alienhead a few times in order for the laptop to respond. Is there anyway to fix this?
  2. inap
    inap .........................
    Alienfx is kinda glitchy, a power drain should fix the problem.
    Shut down
    Take battery out
    Press power button for 20 sec
    Put back and see if it helps.
  3. csin
    csin Notebook Consultant
    Make sure to unplug the AC adapter too.
  4. inap
    hahha yeah that too sorry was typing on the phone.
  5. faelken
    yeah i tried doing that and I still think it still is not working very well. Also I've noticed that I think sometimes (not sure if it is always after discharge) when i turn on my computer, the alienhead (zone 1,2) do not have lights on at all even though the keyboard is lit. I have to load to windows and open alien command center and reapply the color to get the alienhead light back on. So is it software p[roblem or hardware? thanks!
  6. faelken
    update: i noticed now you can disable Status lights (zone 1,2 and the bar with the eject play sound bar above the keyboard) when you press FN+11. So I did that, and then turned on the lights again by pressing FN+11. ALl the lights turn on except for zone 1,2. This kind of replicates the problem when I start my laptop.
  7. Khybrid
    Khybrid Notebook Consultant
    Lol that happens to me sometimes too but only when I start it up from Hibernation. If it happens I just reapply the theme not a big deal takes like what? 5 seconds? :p
  8. caes2004
    caes2004 Company Representative
    Hi, try to download the latest version for command center 2.5.54.0 and also download the latest BIOS and touchpad driver. Thanks, Adriana (alienware quality)
  9. faelken
    Yes, I've actually done that for 2 weeks or so and I have not seen any AlienFX problems anymore.
    (both updates were quite recent) for those who need to fix this issue
  10. BatBoy
    BatBoy Notebook Nobel Laureate
