After I updated from 1709 to 1803, there was a 498MB OEM partition. I want to know how to delete it?
Discussion in 'Windows OS and Software' started by Maomaoa1, May 1, 2018.
  1. Maomaoa1
    Maomaoa1 Notebook Enthusiast
    I don't know how to send picture
    I just want to know how to delete this partition?
    Vasudev likes this.
  2. Ultra Male
    Ultra Male Super Tweaker
    I wouldn't touch a system partition if I were you
    toughasnails, Moz@rt and Vasudev like this.
  3. Moz@rt
    Moz@rt Notebook Enthusiast
    Completely agree with @Phoenix. Doing that is screwing with the recovery files AFAIK.
    Ultra Male likes this.
  4. Token CDN
    Token CDN Notebook Consultant
    I wonder if the OP is referring to this issue:
    • Some users report that a new partition is created after upgrading that they can't interact with. I did not experience this, but you may want to run Disk Management to remove it or hide it. If that does not work for whatever reason, use a program like TestDisk to remove it during boot.
    I've read a few reports about that recovery partition being assigned a drive letter that it shouldn't be.
    I would recommend do some more research before deleting it though
    Vasudev and jeremyshaw like this.
  5. StormJumper
    StormJumper Notebook Virtuoso
    Look online there is help on how to do this. If you don't need the REcovery Partition then follow the online instructions and that will permanently remove it-but remember once gone that is it unless you created or have the Factory REcovery media. And 498MB is crumbs removing it won't give you terabytes of space so my advice leave it.
    toughasnails and Vasudev like this.
  6. Vasudev
    Its only needed if you do use Reset My PC through Win 10 instead of usual USB bootable ISOs.
  7. Atma
    Atma Notebook Deity
    I just installed cumulative update KB4103721 and have a new drive E.
    Is it safe to just get rid of it? It doesn't look like its a recovery partition. Also, got a blue screen memory management error after restarting.
    KY_BULLET and Vasudev like this.
  8. StormJumper
    Unless you sell it-the amount of spaced saved is pittance in space saving.
  9. Vasudev
    What are you saying? I don't sell HDDs at all.
  10. alexhawker
    alexhawker Spent Gladiator
    Sell the notebook?
    Vasudev likes this.
Similar Threads - updated 1709 1803
  1. kojack
    10
    830
