Aero with XTU issue
Discussion in 'Gigabyte and Aorus' started by Sabs47, Aug 3, 2019.
  1. Sabs47
    Sabs47 Notebook Consultant
    Need some help. Everything on my Aero OLED was fine until I turned on XTU. Set the offset to -0.150 and now all of sudden my cpu fans are getting the computer ready for take off and the cpu is constantly at 75C. How do I fix this? Before XTU I was resting at a good 39C
    Help would be greatly appreciated
  2. 4W4K3
    4W4K3 Notebook Evangelist
    A screen shot of your current settings within XTU would be helpful to pinpoint the potential problem.
  3. Sabs47
    Bud, I freaked out and uninstalled the damn software. Even system restored and I'm still hearing the fans ready for take off and the gpu is all over the place in terms of temperature
  4. Sabs47
    So it keeps bouncing from 49 to 62 to 73. Im not sure whats happening here
      File size:
      1,015.6 KB
      57
  5. dumpsterj
    dumpsterj Notebook Guru
    I had one laptop that would retain the XTU settings after reboot. You might need to reload it and put it back to stock and then uninstall it.
  6. Sabs47
    I Tried doing that but I think it needs a fresh install. I ended up doing benchmarks and what not and now I'm using xtu. It's not my preferred software but it's getting the job done surprisingly well
  7. yosv211
    yosv211 Notebook Consultant
    Its hard to completely delete XTU. Last time I used it on another laptop I had to install a frehs Win 10.
  8. Sabs47
    Did you have to install using external media or just through the recovery on your computer?
  9. yosv211
    i downloaded from the intel website
  10. Sabs47
    Well I ended up doing a fresh windows install and the computer is so much more balanced on throttle stop vs XTU.
