aero 15 xa OLED display problem "screen bleeding" on grey background
Discussion in 'Gigabyte and Aorus' started by Dr Schall, Jan 29, 2020.
  1. Dr Schall
    Dr Schall Newbie
    Hi everyone,
    yesterday i got my new Aero 15x (OLED UHD Display i7-9750H RTX 2070 Max) Notebook and it has screen banding / bleeding on the OLED display, when having a grey background, or for example using windows 10 dark mode.
    This occurs especially 20%-100% brightness on grey color or any other dark color with some grey.
    There is a dark big stripe on the right side of the screen[​IMG] https://photos.app.goo.gl/kpBsicT9DXnm8ZXc7 <- refer to pic.
    This occurs especially when working in darker area, during daylight it is harder to see.
    I did some research on the internet and didn't find much info, just one guy that faced this issue on 4-5 replacement devices before he decided to buy another brand instead.
    I am wondering if its a serial failure or general issue with this panel generation or device.
    EDIT : you can test it yourself with the following picture -> https://photos.app.goo.gl/WYcNLxF7QJprp6fS6 (the recommended standard by Gigabyte with RGB values 110/110/110)
  2. Dr Schall
    Dr Schall Newbie
    ...not sure if i put in the link to the google drive picture correctly. Just let me know if you can see it...
  3. CocoLoco
    CocoLoco Notebook Guru
    I can't see the pic.
    Dr Schall likes this.
  4. Dr Schall
    Dr Schall Newbie
    Just updated the link, now it should work
  5. CocoLoco
    That looks like a defect to me.
  6. Dr Schall
    Dr Schall Newbie
    QUICK update : i got another replacement from my dealer with exact same issue and now opened up a ticket at Gigabyte support to get some info on the problem. I want to avoid to send my replacement back and just get a 3rd Laptop with exact same issue. Keep you posted.
    EDIT Today : i got feedback from Gigabyte support now after 5 days waiting for reply
    they pointed out that the picture i took was with 1/15 of a sec exposure time and that this is not how the human eye sees the world. So basically they stated that due to the long exposure time, the picture shows the effect more dramatically. They gave the hint to re-check the so called Black MURA effect with following picture settings R/G/B (values 110/110/110) with > 300 nits ambient light. If it is still visible, it seems out of spec and i should go for RMA.
