Aero 15 X9 is bios locked at low clock speed when on battery
Discussion in 'Gigabyte and Aorus' started by fscussel, Oct 13, 2019.
  1. fscussel
    fscussel Notebook Evangelist
    When I'm on battery it's fixing the cpu speed at a low level (0,8ghz (8 x 100) or 1,7ghz (17 x 100)). I have checked the powerplan and it's set for high performance, with minimum processor speed of 80% and maximum 100%. I've checked with AIDA and it's not throttling either. So I can only conclude it's bios based. You buy a hell of a machine and they cap you at a low speed clock when on battery. If I wanted a desktop, stuck on AC, I would buy a desktop.
  2. custom90gt
    What is your fan profile set to in gigabyte control panel? Sounds like it is set to quiet to me.
    Meetloaf13 and alaskajoel like this.
  3. fscussel
    it's set to normal.
  4. custom90gt
    So mine is also limiting the CPU to a limit of 20W (runs at 2.1GHz all core under Prime95 for me) when I boot with the smart fan controller set to quiet. Even if I switch to normal or gaming it doesn't fix the limitation until I restart. After restarting with the fan profile in normal I am able to hit max boost clocks under Prime95 without issue.
    Are you running throttle stop or XTU? Perhaps your speed shift settings are limited?
    You can also use throttle stop to disable and lock turbo power limits if you can't find another way around it.
    I wouldn't think your X9 would be much different than my V8.
