Aero 15 X w/ 1070 Max-Q
Discussion in 'Gigabyte and Aorus' started by rickybambi, Sep 25, 2017.
  1. Shermo
    Shermo Notebook Enthusiast
    Bought a mini Thunderbolt 3 dock so I have one cable connection when using it at my desk, but seems the laptop is not capable of driving two monitors at once via the Thunderbolt 3 connection?
    This is the one I bought:
    https://www.amazon.co.uk/gp/product/B07BJJX47G
    The laptop can do one via Thunderbolt 3 and one via the mini displayport though, although I did have weird flickering on and off via mini displayport until I forced it to use Nvidia graphics.
    Think I'll look at a cheaper option for the Thunderbolt port if it can only drive a single monitor, annoyingly my Dell monitors can only do 1920x1080 via HDMI instead of their native 2560x1440 so I cannot use the HDMI port, although I might try a HDMI to DVI cable as that might work?
  2. megadip
    megadip Notebook Enthusiast
    Having an Kernel-Power, event id: 41 critical event error.
    Randomly rebooting my laptop.
    Anyone seen this before? Ive had my laptop repasted by HID .
    Currently not undervolting, just running stock settings and plugged in the whole time.
    Screenshot of the event log:
    https://gyazo.com/dff072a128edaec08503d8fe4778e1ac
    Also having issues with the left shift. If i am running in game, i constantly have to re-press it to continue running.
    Its very sporadic .
    Please HELP!
  3. DamianD
    DamianD Newbie
    I own the 4k model and the only issue I have is the oversaturation due to 100% Adobe color space in apps which can't manage the color space. I know from Eizo monitors that you can set the color space to srgb for such apps which can't handle Adobe rgb. But I noticed this is not possible with this monitor because there is not such function in place. Is there any other solution?
  4. Junz Ramdan
    Junz Ramdan Newbie
    Hi guys, anyone having CUDA toolkit install on AERO 15x v8? Preferably version 9.0 ++
    I had successfully install the toolkit, yet when I want to try running the CUDA samples on VS, it always failed to start (no CUDA-capable device is detected).
    Anyone having the same problem? Or do you guys know what should I do to fix it?
    (CUDA toolkit 9.0 and driver 388.92)
  5. gnlu26
    gnlu26 Notebook Consultant
    Sounds to me like you're running your code on the intel graphics card, and your nvidia card is asleep.
  6. Junz Ramdan
    Junz Ramdan Newbie
    I changed the 3D global setting and the VS program setting in NVIDIA control panel to use the NVIDIA card as its preferred graphic processor.
    Is there any other way to force the laptop to use nvidia card?
  7. Shermo
    It should switch to nvidia if you connect a monitor to the mini displayport.
    Also you are iterating all devices and not just trying the first one?
  8. g85222456
    g85222456 Company Representative
    cuz there's only on DDI injected into the TBT port. However it should be no problem to output the QHD through HDMI. Maybe try different cable
  9. Shermo
  10. g85222456
