Aero 15 X w/ 1070 Max-Q
Discussion in 'Gigabyte and Aorus' started by rickybambi, Sep 25, 2017.
  1. sockfish
    sockfish Notebook Consultant
    Not totally confirmed but after the last keyboard update, I have not experienced a double key entry.
    New Razer Blade looks nicer but does seem significantly more expensive.
  2. Salman Daha
    Salman Daha Newbie
    Just bought an aero 15x 2017 locally but have a minor issue.
    The seller restored the device but I think he used a non oem reset or fully wiped the drive as theres no gigabyte software, ie smart manager, fusion, drivers, etc and device also seems to run not stable. I tried to do a "factory restore" but that option is not there and can't make a smart usb backup as an error says this windows installed is not configured by gigabyte.
    So anyway to download a full oem aero 15x .iso or full ssd image to make the device factory reset complete with all gigabyte software and drivers or someone have a "smart usb backup" which I might be able to download and make a usb with that backup and restore my laptop to a gigabyte spec windows.
  3. ramiro9
    ramiro9 Newbie
  4. Skylake_
    Skylake_ Notebook Consultant
    So, MSI owners buy Gigabyte Power Units and Gigabyte owners buy MSI Power Units? LOL
  5. Playtoreview
    Playtoreview Newbie
    Just an FYI but the latest bios still does not have XMP support. So don’t bother buying faster than 2666mhz ram.
    I foolishly prebought some 3000mhz ripjaws that will probably never run at their full potential in my 15x.
  6. TLCH723
    TLCH723 Notebook Consultant
    Does it works with the 3000MHz? There is a report, from Ken from gentechpc, saying that it doesnt work.
  7. Playtoreview
    Playtoreview Newbie
    Boots but at 2400mhz and with poor timings.
    I was hopeful they would release xmp support in the bios but with th US resellers all pulling the faster ram from customisation I’m not holding my breath.
  8. TLCH723
    One more question, did your RAM work before the BIOS update?
  9. Playtoreview
    Playtoreview Newbie
    Yes. Worked from FB05.
    It’s actually the 3200mhz Ripjaws.
    I may just sell this for a loss and buy the Razer.
  10. Fungus99
    Fungus99 Notebook Consultant
    I went to a store and had a look at a demo aero 15.
    Assuming the aero 15x and 15x/w V8 have the same design, I've noticed the bottom of the bezel is a separate stripe that isn't flush with the rest of the bezel reason being the bezel stripe that lays on top of the side bezel whilst the section the goes around the display area is just pushed inwards and as a result the corners on both sides show a small gap.
    xDjinn likes this.
