Aero 15 X w/ 1070 Max-Q
Discussion in 'Gigabyte and Aorus' started by rickybambi, Sep 25, 2017.
  1. wintermutex
    wintermutex Notebook Enthusiast
    if they ship a new 15x with less than a 1070max-q I’m gonna despair :/
  2. Shinoke
    Shinoke Notebook Geek
    He was referring to the 14X for the GTX1050Ti
    So no change for the graphics card currently it seems, which makes sense.
    So very likely it'll still be the 1070max-q, just with a new processor and some screen options (higher res option). Hopefully a refined keyboard and improved base screen, but we'll see.
    And perhaps the 2070max-q by the end of the year!
  3. veselinn
    veselinn Newbie
    Hello, long time stalker, first time poster here
    I recently got the Aero 15 X(this thread convinced me to get it :D). I was trying to find some for the clock speeds of the 1070 Max-Q. Naturally the 1st place I searched was https://www.notebookcheck.net/ as they have a pretty comprehensive list of CPU and GPU. Their 1070 MaxQ page (https://www.notebookcheck.net/NVIDIA-GeForce-GTX-1070-Max-Q-GPU-Benchmarks-and-Specs.224732.0.html) lists the boost of the 1070 MaxQ as "the Boost (1265-1379 MHz)".
    But I'm getting higher sustained clock speeds. [​IMG][​IMG] This is just after a ~2.5 hours gaming session. Fans at 100% + cooling pad + CPU undervolting.
    Usually while I'm gaming(Overwatch, Grim Dawn, Hitman) I alt+tab to see the GPU clock speed, most of the time its around 1450MHz).
    Any ideas where this difference between the notebookcheck's specs and the results I'm getting is coming from? Is the Open hardware monitor bugged? Any idea how I can measure the average clock speed of the GPU?
    edit: correct img url
  4. Paperless
    Paperless Notebook Enthusiast
    Question for owners: Does anyone have a Thunderbolt 3 dock they can recommend to me? I need one that will charge the laptop as well as provide me two HDMI outs, or a display port & HDMI to run to a 2 external monitor setup.
    Also, anyone else having a problem getting it to sleep or shut down after installing the fall creators update?
    Lastly, has anyone had any luck doing a clean install themselves and then installing the Gigabyte Utilities separately?
    Thanks - really need a dock recommendation!
  5. HussainQ
    HussainQ Notebook Evangelist
    I cannot recommend any docks, but I would like to say that the laptop cannot be charged through the TB3 port.
  6. sironlin
    sironlin Newbie
  7. baniels
    baniels Notebook Consultant
    For some reason my webcam is not present in my device manager. Anyone know what driver will bring it back?
    EDIT: Nevermind. I just flashed the latest BIOS and it popped back up.
  8. HussainQ
    It was probably disabled in smart manager.
    baniels likes this.
  9. kkroz
    kkroz Newbie
    Hi there guys !
    I need your help please, I received my Aero 15X a few days ago.
    Everything in the computer is awesome but the keyboard is a complete mess and I would like to know if it's normal and I have to deal with it or if the issues could be solved if I send it back to Gigabyte.
    I have problems with repeated keys : sometimes keys just double randomly and make "f*ckcing double press slike" that. I used the tutorial about bouncing keys and regedit, it now happens less often but still twice in a line of text.
    And issues as well with keys that need huge press to be activated. Meaning the key is pushed down but it doesn't register, I have to press it like really hard. And few keys can't be kept activated like Alt or Shift even if you press hard it doesn't keep on and then "You MISS cAps" = I never left my finger from Shift while writing it.
    Just to know if people are facing those issues or not facing those please ? Then I know if I send it back if I can hope for a solve of those problems or if I have to deal with it.
    Thank you a lot for reading guys !! Have fun in life ! :)
    margroloc likes this.
  10. baniels
    Thanks. You're right.
