Aero 15 X w/ 1070 Max-Q
Discussion in 'Gigabyte and Aorus' started by rickybambi, Sep 25, 2017.
  1. Drekiko
    Drekiko Notebook Guru
    Can you provide some of those articles?
  2. Flip1
    Flip1 Notebook Enthusiast
    You can read through the aero 15 owners thread for a start
  3. Drekiko
    Read through all of those already. Didn’t get a sense that the screen was garbage. Some had defects or screen bleed. But, wouldn’t use the word garbage to describe what some experienced.
  4. Gumwars
    Gumwars Notebook Consultant
    It was one person complaining about the screen quality. All of the reviews place it in the middle of pack. sRGB is close to 100% and Adobe RGB is around 60%. The Pantone calibration brings the deltas into a narrow range which make it usable, but not ideal, for content creation. The problem with the funky backlight issue is tied to a Windows setting when the screen is at or below 20% brightness, other than the 60hz refresh rate, there isn't anything to complain about. It's a good screen on a great laptop. Could it be better? Sure, a 120hz panel would be awesome or one that's closer to 100% Adobe RGB but for what this laptop does the equipment is more than sufficient at the price point.
  5. redq
    redq Notebook Enthusiast
    Do you guys think the backlight bleeding issues are overblown?
    I am thinking about getting this but i'll be moving from US after buying this so i'll have no chance of returning. I don't want to be dissapointed in a 2k device.
    There really is a lack of choice in 1070 laptops. MSI Stealth looks OK but then you'll have to live with 120hz TN which is meh or a pen-tile 4K which is also very meh.
    Maybe the Aero 15X is worth it even with the backlight and keyboard issues.
  6. HussainQ
    HussainQ Notebook Evangelist
    IMO the backlight bleed issue is less of an issue with the 15x compared to the 15 (they might have ironed out some kinks). But it's still a lottery. My Aero 15 has a great screen with minimal to no issues.
  7. buddy1065
    buddy1065 Notebook Evangelist
    Same here.
  8. DemShrimp
    DemShrimp Notebook Enthusiast
    The monitors are plugged into my external sound card with balanced RCA cables. The sound card is connected to the Aero via USB.
    Yes, the ferrite core is still on the charger.
  9. sockfish
    sockfish Notebook Consultant
    Just put in an order for mine through Gentech, they seemed to have the most promotions, though still fairly basic. Pretty much just opted for the free backpack and mouse, along with the Grizzly thermal. Looks like most retails are out of stock until estimated december 25th!
    GenTechPC likes this.
  10. DemShrimp
    I am noticing an odd shading pattern at the bottom of the screen every time I turn it on. As soon as I change the brightness it disappears:
    When screen has just turned on: https://imgur.com/sKycVp7
    After I have changed the screen brightness: https://imgur.com/lc6HQi8
    It only seems to happen when the screen is on low light, but as soon as I have turned the brightness up, I can turn it back down to low and the pattern is gone.
    Any ideas what it could be?
