Advanced LG Gram 2021 tweaking
Discussion in 'LG' started by slavisv, Jul 3, 2021.
  1. RS4
    RS4 Notebook Consultant
    My power options are set to "Never" put the device to sleep but none of the "screen off" apps work, all of them put the laptop to sleep instead of just turning off the screen. Hopefully someone tests the apps on the new Gram 2021 and finds a way to make these apps functional again.
  2. hfm
    hfm Notebook Prophet
    I'm getting the impression it's more a windows function than anything specific to Gram, I can try it on my older Gram 17 at some point
  3. mitebbots
    mitebbots Notebook Enthusiast
    Would you recommend the 2021 Gram 16"?
    coming from 7th gen 1080p Samsung.
    I see little else that fits. Thanks
  4. RS4
    Yes, looks like it is the same with all Windows 10/11 laptops, check it once and post here so we can narrow down the cause.
    @extremecarver @skipper63 @slavisv Can you test this in your Gram 2021? Why are all such apps putting the laptop to sleep instead of just turning off the screen?
    https://sourceforge.net/projects/doff/
  5. RS4
    Please try and report back, i was hoping some solution can be found but nobody is replying on this thread.
  6. Triskite
    Triskite Notebook Geek
    normally i use nircmd and autohotkey for this.
    nircmd monitor off
    https://community.chocolatey.org/packages/nircmd
    but yeah doesnt seem to work on gram... maybe their multimonitor exe?
    https://community.chocolatey.org/packages/multimonitortool
    edit: nope. and all the command line stuff ive found also seems to sleep it... maybe something else from:
    https://superuser.com/questions/321342/turn-off-display-in-windows-on-command
  7. RS4
    I have tried everything, all the apps and programs for "Screen off" function and nothing works without putting the laptop to sleep. These apps still work fine on the old laptops and Windows 7. I just close the laptop lid 70% so that the screen is switched off, not ideal but there is no other option.
  8. Emtee_
    Emtee_ Notebook Enthusiast
    Just a visitor here with RBS 2020 13" gaming laptop, C10 reporting sometimes doesn't work (after resume from standby often) but discharge, estimated battery remaining and temperatures indicate that C10 actually still works even if it is no longer reported. (CPU package wattage is bugged in this state as well, showing double wattage numbers)
    Seems like a bug that is affecting a multitude (if not all) of laptops which support C10.
  9. slavisv
    slavisv Notebook Enthusiast
  10. skipper63
    skipper63 Notebook Consultant
    Try this:
    https://twinkletray.com/
    I downloaded it to change easily the brightness at each monitor at my multi monitor setup and there is an option to put all monitors at sleep and works fine.
    I never needed just to put the laptop screen in sleep, windows does it automatically for me with the power options
