Acer vs Lenovo vs Medion - please help
Discussion in 'What Notebook Should I Buy?' started by thesanchez, Jan 26, 2021.
  1. thesanchez
    thesanchez Newbie
    So I'm looking at getting a new laptop and have come across these 3. They all have my preferred 15" screen, are a very similar price at the top end of my budget and all have, as far as I can see, fairly similar specs:
    Acer Aspire 5 - https://store.acer.com/en-gb/acer-aspire-5-laptop-a515-55g-black-1
    Processor - Intel Core i7-1065G7
    RAM - 16 GB
    SSD - 1 TB
    Graphics - NVIDIA GeForce MX350 2GB
    Lenovo Thinkpad E15 - https://www.laptopsdirect.co.uk/len....6-inch-windows-10-pro-20td0005uk/version.asp
    Processor - Intel Core i7 1165G7
    RAM - 16GB
    SSD - 512GB
    Graphics - Integrated Iris Xe
    Medion Erazer Deputy P10 - https://www.laptopsdirect.co.uk/med...-ssd-15.6-inch-144hz-gtx-30029475/version.asp
    Processor - Intel Core i7 10750H
    RAM - 16GB
    SSD - 512GB
    Graphics - GeForce GTX 1660 Ti 6GB
    My question is how would you go about separating these options?
    I know the Medion is marketed as a gaming laptop. I don't necessarily need something for frequent heavy gaming, but it's not obvious to me what this laptop sacrifices for its slightly more gaming focus.
    Many thanks in advance for any opinions / advice.
  2. Reciever
    Reciever D! For Dragon!
    Higher performance = higher power draw
    So for me, without looking at the machines, battery life would be the obvious sacrifice
  3. thesanchez
    thesanchez Newbie
    Thanks for the reply, and I think you hit the nail on the head. A bit more research suggests the battery life of the Medion is only a couple of hours. Not a deal-breaker as I'll so rarely use it without being connected to power, though it does seem rather paltry.
    Does anyone have any insight to any weaknesses in build quality / durability of the 3?
    Struggling to pick between them.
  4. KING19
    KING19 Notebook Deity
    It depends what you're going to use the laptop for. The Medion has the best specs of the 3 and it has good build quality since its made of aluminum but if you're not interested in playing the latest AAA games and you just using it for basic/work related tasks then go with the thinkpad by far, it has great build quality and great battery life.
  5. LaMOi
    LaMOi Notebook Guru
    I agree. To me the Medion seems to have the best components for the money.
    I’ve done a lot of research in the last few months as am considering buying a laptop myself.
    One factor that helped steer my decision making process was the fact that I intend to use my laptop at home plugged in. I’m not bothered about mobility. Which frees me up with regard to buying a powerful laptop that will likely consume more power than others.
    So I agree with the previous poster how you plan to use the laptop should ultimately help you your decision.
    Also in my understanding having a dedicated graphics card is better than not, as I assume graphics cards can be utilised by the laptop for things other than games e.g video editing/photoshop etc.
