Acer Asp 6736G problem
Discussion in 'Acer' started by lostrick, Sep 11, 2012.
  1. lostrick
    lostrick Newbie
    i have an Acer Asp 6736G
    it's working smoothly, but the problem is it get turned off instantly when i'm using it, i don't know what's the problem, sometimes when i just turned it on 10 secs after that it get off by itself but sometime it can hold up to 1 hour
    it's not because it's hot, because usually it get turned off right after i turned it on
    i tried to open it and apply some thermal paste (cause the thermal paste is already dried up) but it's not working at all, it still have the same problem
    i tried bringing it to an acer service center but they said "the motherboard is the problem so u should buy a new one" (like hell!).. :cool:
    so any suggestion? :)
  2. popeye1128
    popeye1128 Notebook Consultant
    Either the power brick or the motherboard (capacitors/power circuit) are the most likely. The service center folks are probably right.
  3. lostrick
    lostrick Newbie
    i know buying a new motherboard would definitely fix it, but i don't think the problem is the whole motherboard cause it's working fine, besides it gets turn off by itself
    most of my friends are facing this problem too when using acer laptop after a few years, and none are able to fix it
  4. popeye1128
    There are capacitors where the power plug goes into the motherboard. Maybe you can replace them without trashing the motherboard. Good luck!
  5. sunster168
    sunster168 Notebook Consultant
    I would personally try this first before deciding to buy a new motherboard or simply discard the laptop. But I guess it would also depend on where you live as I live in a place wherein labor is relatively cheap. But if so, I would still sell it )the laptop) as soon as it is fixed as sometimes these problems could sometimes turn out to be chronic.
