Acer 5672 Cooling Pad!
Discussion in 'Acer' started by benk87, Oct 27, 2006.
  1. benk87
    benk87 Newbie
    I would greatly appreciate it if you guys could give me some info on a decent cooling pad that will reduce the heat of this computer! Preferable I want input from the people that have the computer and the cooler. I dont feel like taking my computer apart and doing all those cooling tips that they have posted in the forums. I need an easy way out.. I am sorry if this has already been posted but I dont want to dig. Thanks in advance!
  2. PRH
    PRH Notebook Consultant
    No easy way out. The best cooling pads don't fix the heat around the mousepad or do anything significant in terms of cooling.
    The vent cover mod is needed to create circulation inside the chassis.
    Want an analogy? Try unplugging your refrigerator, and then using a room fan to blow on the outside of the closed refrigerator and see how long your food lasts...
  3. applx
    applx Notebook Consultant
    PRH you didnt answer his question!
    Get a Cooler Master :D
  4. Hipopanonamous
    Hipopanonamous Notebook Enthusiast
    I disagree with PRH. I have the 5672 (x1400 version) my touchpad would get hot enough to cook an egg (no I never tried :) )
    I use the BYTECC Notebook Cooling Pad ( Aluminum ) Powered by USB port Model NC-500
    http://www.newegg.com/Product/Product.asp?Item=N82E16834999336
    This isn't the quietest one, but it definitely works in keeping my temps down, (including HD), even at 100% cpu usage.
    Let me know if you have questions
  5. benk87
    benk87 Newbie
    ....ok i have done the black cover thing.. but I need a good suggestion for getting a pad.. I am getting one reguardless of what you say PRH....So make a suggestion please...
  6. PRH
    I had mine on a Lapcool2 that is the best of the best in terms of amount and direction of air that blows right onto the bottom of the laptop. After 6 months the hard drive failed. Then after another month the motherboard and cpu had to be replaced when smoke came out of it while sitting on it's stupid lap cooler.
    Try cleaning out your radiators too. After only 7 months, I was amazed the amount of dust bunnies clogging up the radiators.
  7. benk87
    benk87 Newbie
    is it possible to turn the fans so it is sucking hot air away from the laptop? will that help it any?
  8. raulfverine
    raulfverine Notebook Enthusiast
    Im using 5672WLMi with notepal notebook cooler by cooler master. Its amazing! temperature drop from 78C to 51C.
    If you intend to buy, get the model customade for widescreen notebook, it has 3 fans.
    cheers!
