Accurately "Adjusting" M17x-R2's RGB LED via CCC
Discussion in 'Alienware 17 and M17x' started by Megacharge, Nov 14, 2010.
  1. Aedaric
    Aedaric Notebook Geek
    Quick and Easy instructions for a great looking desktop! Thanks +Rep
  2. Devnant
    Devnant Notebook Enthusiast
    man great colors! thk u very much!
  3. Megacharge
    Megacharge Custom User Title
    I'm glad I could be of help. Thank you.
  4. Megacharge
    10.11, and yes I would install AMD drivers instead of Dell drivers. Dell's have been known to have/cause issues.
  5. 5150Joker
    5150Joker Tech|Inferno
    The new Catalyst 10.12 with CCC2 (you must replace the notebook CCC install folder with the desktop CCC2 folder) feature a way to change the color temperature of the display. Default is 6500k and I moved mine to 6700k which reduced the red tinge quite a bit.
  6. steviejones133
    steviejones133 Notebook Nobel Laureate
    Ive seen the temperature slider before when i had my external monitor hooked up...also the checkbox just above to extend....all of this were prior to 10.12 ..... noticed it as i was trying to calibrate both displays at the same time and was one of the settings i messed about with too.....havent installed CCC 10.12 (desktop version) yet.....
  7. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    Its impossible to share a calibration setting for one screen and have it work for everybody else the same.
    Even within the same model of the same screen there are variances and each person screen is different.
    As a semi-professional photoshop/video editor I work with calibrated screens, considering I have seen so many "wow this looks great" posts I can probably conclude this is not anything close to "accurately calibrated' as proper sRGB calibration actually looks pretty dull and bland and not very pretty.
    This thread should be called "settings to make your M17x display look good" it should not have the word accurate or calibrated anywhere in it.
    Calibrating a monitor requires a lot more tweaks than just 2 settings as well.
    If you really want to learn about screen calibration you need something like this:
    http://www.amazon.com/Datacolor-DC-...55LC/ref=sr_1_1?ie=UTF8&qid=1292328754&sr=8-1
  8. 5150Joker
    Yes technically these adjustments are not accurate but rather a matter of preference. Whether he used the proper semantics for the thread title doesn't really matter. He never advertised that a colorimeter was used in creating his settings. I think most people are aware of this and don't feel the need to "call him out" on it. ;)
  9. RainMotorsports
    RainMotorsports Formerly ClutchX2
    Careful with the vibrancy and saturation settings though you lose dynamic range and colors wash out a bit harder. Why i always hate trying to decide where I want to put it.
    Calibrating a screen for accurate color, and what has been done here have NOTHING in common. None of the screens available for this laptop and for most even display any majority of the viewable color spectrum nor are able to be calibrated properly with professional tools.
    The idea behind calibration is usually for Photographers, Graphic Designers and anyone working with print media. Print media can not reproduce what is seen on screen, nor will a screen EVER display what you see in print. The whole idea is to get all your production displays regardless of manufacture, age, capability to display as close to a color space.
    In that respect even the same display cant be calibrated using the same file as another. If you ever try to use a calibrator on your settings, it will either reset them or fail. Screen has to be at a certain gamma setting.
    A "Calibrated" screen actually looks a tiny bit yellowish in comparison with its original profile. Looks like crap for gaming if you ask me, gets worse with screens that can't be calibrated properly. I usually do like you do for the laptop. Get i to where it looks right to me.
    Its also impossible for someone to "Accurately Calibrate" a screen by eye, I am sure you have seen some of the color illusions that show you why. It is however possible to make something agreeable as you have. Not everyone see's color the same though... or at all.
  10. BatBoy
    BatBoy Notebook Nobel Laureate
    Reminder of the forum rules -
    There is no need for back and forth bickering. We all have opinions. Sharing your opinion is fine just do it with a bit of tact.
    If there are any further posts which violate the forum rules, infractions will be issued. If you have a problem with a post, report it and leave it to the mod team to take action.
    For those of you who want to discuss calibrating the 17xR2 display using ICC profiles, please see this thread:
    http://forum.notebookreview.com/ali...led-calibrating-icc-profiles-etc-m17x-r2.html
    This thread is for tweaking the display settings using the CCC control panel.
    Questions, PM me or the lead moderator.
    Thread re-opened. Thanks.
