Absolute BEST Laptop Cooler??
Discussion in 'Accessories' started by Shakenbake158, Aug 24, 2011.
  1. Shakenbake158
    Shakenbake158 Notebook Consultant
  2. cenix
    cenix Notebook Consultant
    yes, the link you posted is the cryo lx. i have that exact same one and it's decent but it still needs some improvements. i think it looks the best and the materials (all aluminum) is pretty nice. i don't think you can go wrong between the coolermaster sf-19 and the nzxt cryo lx especially if they fall into your budget.
    to answer your real question, i don't think there's an absolute best cooler out there yet.
  3. Shakenbake158
    I like how the SF-19 is powered by an AC adapter though, I dont like the idea of the Cryo constantly pulling power from my USB ports to power 3 120mm fans, can you use an AC adapter for the CRYO LX, instead of the USB power?
    Thanks,
  4. cenix
    yes, the cryo lx comes with an ac adapter. that's what i use because if i run it off usb, the fans slow down noticeably.
  5. katalin_2003
    katalin_2003 NBR Spectre Super Moderator
    The advantage of the Cryo is that it can run off of USB OR external PSU (the size of a phone charger). It also has 5 USB ports on the back (4 if you power it off of USB).
    I have it for my M17xs, replaced the fans with Scythe GT and it does a great job, the stock fans are also good but had those for a good deal.
    Why don't you replace the fans on your Targus if it did a good job?
  6. hockeymass
    hockeymass that one guy
    The Cryo is nice, but it is a beast.
  7. cenix
    how hard was it to replace the fans and how much of a difference in air flow and/or noise did you notice? i heard a lot of people who upgraded the fans say that the stock power source is weak as it is that there was hardly any difference.
  8. Sweet_Ivy
    Sweet_Ivy Notebook Enthusiast
    Well I was thinking of getting a LX myself and found this topic about swapping the fans on the LX. (look are 3rd post on that page about how to install new fans)
    But I decide to go with Cooler Master NotePal U3 just for the fact I could move the fans around.
  9. sgogeta4
    sgogeta4 Notebook Nobel Laureate
    There really is no best universal cooler. You have to look at where your computer heatsink/fan is and look at the design of the bottom of your case. IMO you can build a functionally better cooler than most of those mentioned for only a few dollars by propping up your notebook and strategically placing fans. Not a visually appealing solution, but I'm sure if you had a few dollars more, you could find some creative solutions. I remember a few pics with people taking aluminum file holders (the horizontal ones) and cutting it to hold the fan and power supply.
  10. hockeymass
    The CoolerMaster Notepal series lets you place the fans.
