~-.__.-~ Dell e1505 SYSTEM CRASH ~-.__..-~
Discussion in 'Dell' started by College777, Aug 30, 2006.
  1. College777
    College777 Notebook Enthusiast
    I need HELP ASAP!
    My Dell e1505 this morning would not start up properly. I was infected with some sort of log in/ log off LOOP, which meant my computer logged off immediately after log in, which means i couldn't access my desktop. I tried several restarts, and nothing, so i researched on the internet and found this fix, using the dell XP reinstall CD Recovery system:
    copy C:\windows\system32\config\system C:\windows\tmp\system.bak
    copy C:\windows\system32\config\software C:\windows\tmp\software.bak
    copy C:\windows\system32\config\sam C:\windows\tmp\sam.bak
    copy C:\windows\system32\config\security C:\windows\tmp\security.bak
    copy C:\windows\system32\config\default C:\windows\tmp\default.bak
    delete C:\windows\system32\config\system
    delete C:\windows\system32\config\software
    delete C:\windows\system32\config\Sam
    delete C:\windows\system32\config\security
    delete C:\windows\system32\config\default
    copy C:\windows\repair\system C:\windows\system32\config\system
    copy C:\windows\repair\software C:\windows\system32\config\software
    copy C:\windows\repair\sam C:\windows\system32\config\sam
    copy C:\windows\repair\security C:\windows\system32\config\security
    copy C:\windows\repair\default C:\windows\system32\config\default
    Everything worked fine except:
    Error: File not found (i tried severall times, no file found)
    So i searched the windows repair directory on the CD and thier was no system repair file, but instead a system.bak file, so i was stupid and decided to run my own replacement with the system.bak file, so i did a:
    copy C:\windows\repair\system.bak C:\windows\system32\config\system, and the file copied succesfully, however now i get a BSOD 0x0000007B...
    What do I do? HELP!
  2. Greg
    Greg Notebook Nobel Laureate
    i have a similar problem with an old desktop right now, does anyone know how to fix it?
    Is there any important data on the laptop?
    BTW, if I solve my issue, I'll post my solution for you...
  3. College777
    yes i need the info on the laptop desperately
  4. Greg
    if you have a desktop available (or another notebook), i would suggest getting a 2.5" external enclosure, plug in your drive, and copy the data.
    there has to be an easier way though...do that as a last resort
  5. College777
    yeah i on my desktop... i wouldnt be able to go on the internet if i was on my e1505
  6. College777
    thanks for the advice... i willl do
  7. Greg
    no problem...seriously though, sorry that is the only way i know how to fix it!
