980m vs 1060, What to go for?
Discussion in 'Gaming (Software and Graphics Cards)' started by TheReciever, Feb 4, 2019.
  1. Vasudev
    Very true.
    @TheReciever You need high ASIC %age for 980M to OC very well even with Prema vBIOS. I can OC only max of 150-200MHz and 200-300MHz on memory with little overvolt and still hits TDP of 120W and throttles itself because of 58% ASIC quality.
    Starlight5 likes this.
  2. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Oof, that has to be one of the worst examples I’ve ever seen. Fortunately all my cards are 71-78%
    Vasudev likes this.
  3. Vasudev
    The real value is just worse, I just put the rounded off values, precisely 57.3x% and only 3% people have it.
  4. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Overclocking is never worth it for gaming performance, just for benching.
    That being said, since you have one slot to use and also have the edp display, I would go 1060, and try your luck with MSI afterburner at overclocking + undervolting. Better still, I’d save for the Frankenstein 1070 using a Dell quadro Pxxxx board + 1070 core for 600$, that should do nicely for some time.
    TheReciever likes this.
  5. TheReciever
    TheReciever D! For Dragon!
    I plan to get the 1080 and experiment getting that working with external supplement power from the g65vr. Depends on if I can find the part I need or find someone that can fab it.
    So this is more of a stepping stone card just so I can get a little current. Many mods are being researched at the moment.
    That being said if I can't get the vortex 1080 working then yes I'll be using the 1070.
  6. Kevin
    Kevin Egregious
    This is a precarious position to hold so confidently. There are many scenarios where it isn't going to hold true.
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Increasing clocks on the 980M requires such a large increase in voltage, it turns it into a blast furnace. Even if you get +300mhz in the core, it might add 4-5 FPS TOPS, in ideal situations. Pascal doesn’t even overclock unless you have a custom unsigned bios and a programmer, otherwise all you can hope for is hitting higher clocks at lower voltages.
    Desktops are a different story.
    TheReciever and Vasudev like this.
  8. ssj92
    ssj92 Neutron Star
    I think my 980M died @ +320Mhz on core lol needed 1.2V I think.
    My 680M handles 1.2V fine. 980M was just crap.
  9. TheReciever
    Thanks to everyone for providing the details to give more context. I had only known that an OCed 980m could beat the 1060 but I didnt know that it required such voltage / modding to get there.
    I purchased a 1060 for the Ranger to hold me over until I attempt another GPU upgrade in the future.
    long2905 likes this.
