980m vs 1060, What to go for?
Discussion in 'Gaming (Software and Graphics Cards)' started by TheReciever, Feb 4, 2019.
  1. TheReciever
    TheReciever D! For Dragon!
    https://www.ebay.com/itm/New-Nvidia...rentrq:bb99cc791680abd98fcd0adcffd1bd9f|iid:1
    This is what I am looking at. Given that OCing 3rd party cards doesnt have a good record I dont have plan to tdp mod it, just tune it for optimal performance.
  2. thegh0sts
    thegh0sts Notebook Nobel Laureate
    That's fine. all you need to worry about is that the MXM card fits in the spot for the GPU and that the die and heatsink align correctly.
    I don't use MSI afterburner since running it might cause some anti-cheat apps to think you're using hooks to cheat so what I do is use nvidia inspector to test the OC, create a shortcut, take the command line arguments from the shortcut and create a scheduled task to run nvidia inspector with the command line arguments at login. DONE!
  3. TheReciever
    I just disable the overlay for siege and dont really play much multiplayer games anymore. Single player campaigns are where its at for me.
  4. thegh0sts
    That's why i recommend nvidia inspector because it just runs once to set the clocks and the app will close after it's set.
    it's a "set and forget" type of thing.
  5. RMSMajestic
    RMSMajestic Notebook Consultant
    Performance-wise no doubt go for GTX 1060, or GTX 1070 mxm (they are usually around $500, and believe me, the extra performance is worth the price)
    However there is a reason why those GTX 1060 cards are being sold at the same price or lower than 980m, that is, compatibility.
  6. TheReciever
    To be honest I am just looking for the cheapest card to run PEG/eDP mode but in case I cant ill try to get a 1060
  7. thegh0sts
    It just means you won't be able to use the integrated GPU... Boo hoo! It's preferred to use the dGPU anyway.
  8. Casowen
    Casowen Notebook Consultant
  9. TheReciever
    Yeah only reason I am looking right now is because my 8950m wont boot peg even on the LVDS panel let alone PEG for eDP. But I found a cheap panel to upgrade from my Rangers default eDP panel, so if I can snag that on the cheap then I will feel better about the cost of the 1060.
    Thanks, but I am not looking for a new laptop. The Ranger will very likely be my last laptop, as everything else doesnt measure up to what I want in a machine.
  10. ssj92
    ssj92 Neutron Star
    Go for the 1060. I've owned 2 980Ms, as has @Mr. Fox and they both died for us. They are not good for overclocking as @Khenglish mentioned. They need to be power modded.
    You can flash the Clevo 88w TDP vBIOS if you want to try to extract extra performance, but a 1060 out of the box will work faster. Even in Afterburner, with some voltage tuning, it'll run well.
    120Hz PEG is where it's at. I bet even RTX 2060 would work in the future if it were ever made to work in the form factor.
    I don't think you need to worry about the 60hz panel since the 17 has eDP, which all new GPUs only support. 980M is more practical in a system like mine where you can SLI.
    EDIT: I'd message that seller and see what vBIOS TDP limit it has.
    MSI has 78W
    Clevo has a 88W OC'd
    Preferably it would be nice with a 100W TDP to really open up the card but here's what a few different vBIOSes can do with 1060:
    78W Stock (Optimus): https://www.3dmark.com/fs/15564093
    78W OC (Optimus): https://www.3dmark.com/fs/15551448
    88W Stock (Optimus): https://www.3dmark.com/fs/16841964
    88W OC (Optimus): https://www.3dmark.com/fs/16862393
    Secret Sauce Stock (Optimus): https://www.3dmark.com/fs/16860572
    Secret Sauce OC (Optimus): https://www.3dmark.com/fs/16862440
    Keep in mind, yours will run PEG so should be 5-10% faster across the board.
    Ashtrix, Vasudev and aaronne like this.
