970 EVO too hot or?
Discussion in 'MSI' started by Ivan994, Jan 12, 2019.
  1. kothletino
    kothletino Notebook Consultant
    Maybe this will help you?
    Ivan994 likes this.
  2. Falkentyne
    Falkentyne Notebook Prophet
    If that's directed at me, no room for that on a desktop. The M.2 sits under cards. That would never fit.
  3. Ivan994
    Ivan994 Notebook Consultant
    This will be good if can fit in laptop :D
  4. Papusan
    Depends on the laptop. Apple design everywhere nowadays you know:hi:You forget the Z hight.
    Ivan994, ryzeki and Falkentyne like this.
  5. ryzeki
    ryzeki Super Moderator Super Moderator
    Apple is the pinnacle of what is wrong when designing laptops. If they could solder the damm keyboard keys to the chasis while still resembling a keyboard, they would. They probably will.
  6. Ivan994
    @Falkentyne
    I did this test for you to see and my temp are still perfect. You were right about everything. Sanding is a harder part but still after good sanding you need to have luck to make perfect HS pressure and repaste perfectly.
  7. kothletino
    :/ can't see
  8. Ivan994
    Sorry, my bad :D
    Falkentyne, JeanLegi and Papusan like this.
