8700K temps in Clevo P7xTM1's
Discussion in 'Sager and Clevo' started by woodzstack, Dec 3, 2017.
  1. woodzstack
    woodzstack Alezka Computers , Official Clevo reseller.
    Ah I see where I went wrong, it's the Skylake IHS I needed all the time, for some reason, some part me being so by the book at times just didn't think of the obvious. Must be a brain fart !
    Stress Tech likes this.
  2. Papusan
    Intel and AMD's IHS is concave. They really need lapping!! BitsPower or the orginal lid... Same ****y.
  3. Meaker@Sager
    Certainly no point for the same dimensions but if you need an extra 1mm or so extra height then solid metal will do the job best by far :)
    Papusan likes this.
  4. woodzstack
    right, which was the whole point.
  5. Stress Tech
    Stress Tech Notebook Evangelist
    I just edited my old post. I changed the "Kaby" to "Sky". I said that the Kaby Lake had the 1mm extra height. This is wrong, sorry. Its the Sky Lake lid that has the extra 1mm height! sorry for the confusion. I probably were half asleep then...
    The Sky lake BitsPower lid gave me a 2c drop on max CPU temperatures when on full fans. I had to lap the lid to achieve this effect though.
    Papusan likes this.
  6. Papusan
    Maybe Edit your post #39 as well:D Maybe it is time to wake up?:p
    woodzstack and Stress Tech like this.
  7. temp00876
    temp00876 Notebook Evangelist
    @woodzstack , so the voltages don't really stick after all even in the P870TM. Have you tried setting the value of xtu fan table support to 0 in the oem.ini? It seems to have worked for me.
  8. woodzstack
    where's this file, and what are the rest of your settings ? (in XTU settings ?)
    I found the 8700K tricky to play with, but manageable, the thing is it's plenty powerful at stock, kicks a 7700K's butt for sure on the multithread.
    I do not feel it was less powerful on single thread - like things were spontaneous as I'd expect.
    I do not understand the logic behind the fansetting here though, how did you come to this conclusion or pure accident ?
  9. temp00876
    Oh sorry about that, the oem.ini can be found in the clevo hotkey folder installer. It just basically removes the Clevo Cpu/ram OC utility.
    I just found it by accident. When I rechecked my voltages, it was set on adaptive in the CCC. Whereas, I was sure I set it to override in the bios. Since we've been removing the cpu/ram oc utility in the P870DM/2/3, might as well give it a try. It just happened that they removed the configuration in the setup.ini and placed it in the oem.ini.
    dm477, woodzstack and Papusan like this.
  10. woodzstack
    Thank you.
    temp00876 likes this.
