8600K in eurocom Sky X7C chassis
Discussion in 'Sager and Clevo' started by Otto1984, Feb 25, 2018.
  1. Otto1984
    Otto1984 Notebook Enthusiast
    Hi everyone.
    I am thinking about purchasing a RAIDER 17,3 inch laptop based on the same Clevo model as used on the Eurocom Sky 7C chassis.
    My setup includes the i5 8600K and I was wondering what performance I might expect on this CPU? I am hoping to get it to 4.5Ghz or higher while maintaining reasonable temperatures (around 80 degrees). The machine will replace my current desktop and if needed the panel will be replaced for IPS LP173WF4-SPF3.
    The main concern I have is what can be achieved on this machine with this CPU?
    Perhaps any of you can also tell me what chassis this is in the Clevo/Sager line-up?
    Thanks for any reply and I hope you can show me some good results and convince me in buying this piece of hardware.
    Maarten
    (Amsterdam)
    EDIT: I believe this is the Sager NP9175 chassis
  2. Meaker@Sager
    Those targets are not unreasonable for normal loads with the i5. Higher clocks would likely need a delid.
  3. D2 Ultima
    D2 Ultima Livestreaming Master
    It's the Clevo P775TM1.
    I don't know if 80c at 4.5GHz will work out of the box without delidding the chip in that chassis.
    I can't guarantee being able to overclock to that speed and stress both CPU and GPU on the stock firmware either. It may be possible, I simply don't know for sure.
    That panel is IPS, however I don't know why you want IPS specifically.
  4. Otto1984
    Was opting for this machine:
  5. Meaker@Sager
    Seems like a decent spec to me :)
  6. ole!!!
    ole!!! Notebook Prophet
    if you're targeting good cpu performance, don't skip the deliding step. you can achieve 4.5ghz with good temp with a delid where if not, u might have headaches about it after purchase.
    i got a barebone from RJtech without the CPU and with GPU. you can get CPU from SL with a 4.7ghz sample for cheap and comes with delid, run it at 4.5ghz and you'll have great temps.
  7. Otto1984
    A delid is planned but I don’t trust suppliers do it as they can just say “we did it” charge you for it and you cant check it. So I found a chap who did 90+ delids already and is willing to help me out.
  8. Meaker@Sager
    The temperatures would certainly reveal it and often the sealant will give it away. It is best to run with the lid not re-attached (just leave it sitting on top without sealant held by the socket) of course for best results.
  9. ole!!!
    iirc wouldnt the liquid metal dry up if not sealed? and have to replace liquid metal more often. still much better than mobile skus though
  10. Meaker@Sager
    The socket clamp holds the lid down pretty firmly anyway.
