7970M Dim Screen Fix on R3, Sort Of....
Discussion in 'Alienware 17 and M17x' started by SkylineLvr, Jul 22, 2012.
  1. SkylineLvr
    SkylineLvr Notebook Deity
    While trying to get switching to work and failing at it, I decided to just give up. Since I didn't like the screen dim issue, I reinstalled HWiNFO64. I had to do a clean install of Windows (don't remember why), and just used the newest version of HWiNFO64. When it loaded up, my screen stayed dim. This was strange because before I did a clean install, HWiNFO64 would brighten my screen up.
    I realized that previously I used an older version, version 3.96-1640, and it worked perfectly. I uninstalled the newest version, and reinstalled version 3.96-1640. Once it loaded up, my screen dim issue has been fixed. I remember stating a few times on some threads for others to try and run HWiNFO64 to fix their dimming issues. They reported back that it didn't work for them. I now realize that they may be using a different version. I have tried a few versions, and for some reason, only version 3.96-1640 works for me.
    I have to run HWiNFO64 every time I start up my laptop. Not too big of a hassle for those of us that can't get switching to work properly on the R3s. If you guys are having issues with the dimming, give HWiNFO64 version 3.96-1640 a try. I'm curious to see if this helps others out. Please chime in if it does or doesn't.
    You can download the portable version here or the installer here. I did a google search, and these are the only 2 sites that still have this version up. The second site is in Polish, but all you have to do is click on the orange download button. I hope I'm not breaking any rules posting these links.
    Edit: I've uploaded the file on MediaFire. HWiNFO64 3.96
    reborn2003 likes this.
  2. juliant
    juliant Notebook Deity
    I must agree with you that if you have only the AMD 7970m enabled on the R3 and you remove the driver (control panel remove all amd drivers / driver sweeper / ccleaner) reinstall the latest AMD driver and have the only version you mentioned of the hdinfo the brightness does go up at 100%. Great fix, thank you +rep. Don't you love this forum?! :)
  3. SkylineLvr
    No matter what I did, I always ended up having 2 monitors showing. So I just said forget it and disabled the iGPU. Hopefully I'll be able to figure it out sooner or later.
  4. Alienware-L_Porras
    Great Stuff! Thanks for the fix. +1Rep. Hopefully lots of people will see it and have their computers running at 100%.
  5. GeoCake
    GeoCake http://ted.ph
    Easiest fix so far. Any chance you can upload the program to mediafire or some other file host just in case?
    Rep.
  6. SlickDude80
    SlickDude80 Notebook Prophet
    thanks for posting this Sky...I'll rep when i get home
    Sent from my SGH-T989D using Tapatalk 2
  7. SkylineLvr
    I'll do that after I get home from work.
  8. juliant
    Luis, that's not actually running at 100%. If you do not use your computer for a while, you will still have the dim issue until you restart hdinfo. It is a temporary fix and I hope that one of your tech team will look into releasing some kind of a driver (which I think is impossible since 7970m is not released with this model). Many will love to see the switch working on this system and make use of the IGP.
  9. Joe85
    Joe85 Notebook Deity
    Guys what is this dim screen issue? Will it effect me connecting to an external monitor?
  10. juliant
    The screen issue is because of turning off the IGP... We have to keep it that way until we will have a driver to fix this issue (or maybe there will never be one); most probably you should not have any problems with an external monitor, I tried it on an 50" plasma tv and it worked just fine...
