7970m cooler on 980m
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by JAGMAN, Oct 24, 2021.
  1. JAGMAN
    JAGMAN Notebook Consultant
    i am thinking of getting a 980m to upgrade can i keep the same cooler do i need anything to swap it out?
  2. JAGMAN
    It's a P170EM
  3. Meaker@Sager
    Is the heatsink a single piece or two?
  4. JAGMAN
    It's a two piece heatsink,one for the chip and the other for the memory
    Sent from my M2007J20CG using Tapatalk
  5. Meaker@Sager
    I think you can make it work but it will run pretty hot. The later single peice designs would be better for the 980m.
  6. JAGMAN
    Is it worth it to upgrade it though (since it's old)? I will get it for 150 dollars
  7. JAGMAN
    Will it be plug and play? Or i should do something with the bios or whatnot?
  8. JAGMAN
    Can you help me out please?, does it need custom bios or is it plug and play?
  9. Khenglish
    Khenglish Notebook Deity
    It's plug and play bios wise, but you need to .inf mod the Nvidia driver to install the driver.
    You'll need to shift around the thermal pads on the memory heatsink to cover the 980m power FETs. You may need to buy some pads for this. I think you want 1.5mm.
    Mr. Fox and jc_denton like this.
  10. Meaker@Sager
    You'll also need to boot with driver signing disabled for the driver install.
    Mr. Fox likes this.
