7811FX Upgrade
Discussion in 'Gateway and eMachines' started by waynet, Apr 21, 2014.
  1. waynet
    waynet Notebook Consultant
    This has been my go to computer since 2009, but overdue for an upgrade. Disassembled the whole rig per the sticky (Thx!). The 2 heatsink grilles were caked with dirt/dust. Both fans worked fine, so I cleaned them up and put em back. Replaced the original T8400 with a new T9600, using Prolimatech PK-3 thermal paste. Also re-pasted the GPU. Only had one glitch. Removing the two connectors from the wireless PCB one of the connectors separated from the board. Fortunately they are plentiful, got a new one on ebay. Also added a Samsung 500GB SSD as primary/OS drive. With the 9600 and SSD, the 7811FX is substantially faster. Used Samsung Data Migration software to clone the old drive to the SSD, worked perfect. Guess I'll hang onto this rig for another 5yrs.
    HW Monitor says the SSD idles a good 10degC cooler than the previous conventional drive. GPU idles around 40degC. Man, does this rig rock now!
    stinger608 likes this.
  2. TreeTops Ranch
    TreeTops Ranch Notebook Deity
    WOW, that is good news. I am trying to get up the courage to do same with my P-7805U Laptop. But with x9100 processor.
  3. StormJumper
    StormJumper Notebook Virtuoso
    Lucky you I did the same thing just processor to T9600 cleaned rethermal paste but didn't do the GPU will have to redo it again to see why my system freezes.
  4. stinger608
    stinger608 Notebook Enthusiast
    Awesome Waynet!!
    Last "upgrade" I did on my 7811 was to install the same T9600, dual WD Scorpio Black 320's in Raid 0, and 8 gigs of ram. As you pointed out, it made a world of difference!
    I don't use my ole girl much but when I do use it I appreciate the quality and longevity of these truly awesome laptops!
    Like you, I purchased mine in 09 and it was the first "hotrod" laptop I had ever purchased. I can honestly say, I have never regretted the purchase. :p
  5. TANWare
    Nice Avatar Waynet............
  6. Syngensmyth
    Syngensmyth In All Seriousness
    I still use my 7811FX every day. Only upgrades are 8 GB RAM and SSD. I think the screen may be loosing a little brightness but I just can't kill this thing. Bought a used one as backup for under $300 that works perfectly but of course other family member scarfed it up. I dread trying to replace it. I can't live with less than 17" 1920. I should tear it apart for cleaning but blowing it out still seems to keep it tolerable.
  7. TANWare
    well 1920 is on 1080P as well but again you will loose from the 1200Pyou have now. Trust in I understand this, the P79xx I have would still be my primary if it were not for Windows 8 forcing me to get a new Windows 7 machine before it was too late.
    Save grace is with the Samsung is while only 1080P it is LED backlit 400 nit and 120Hz. Side by side thee is no comparison with this new screen. So I have lost a bit of screen real estate but gained in image quality.
  8. tallan
    tallan Notebook Deity
    My 7811 (bought upon release) was unused for two years and then in a storage locker for another two but when I recently cranked her up she worked perfectly. I'd already upgraded to a P9700 CPU, an Intel modem, and Hitachi 7200 drives in RAID 0 so it wasn't even that slow, but never one to leave well enough alone I upgraded to a Samsung 250 SSD this week. Data Migration did not work for me, and somehow I pooched my RAID install so I ended up going to a fresh install of Windows 8.1 (which has improved a lot since first released) and I'm a very happy camper. I wish the keyboard was backlit, but it has tremendous touch and travel compared to most of the "chicklet" boards on today's laptops so this old girl is still a keeper, even as long in the tooth as she is.
    I looked into another CPU upgrade but the power draw (45 versus 28) for a 10% at best boost in speed (plus the cost) held me back. In fact in one comparison I found from the old days the 9700 outperformed the T9900 in several benchmarks, so with the possible exception of adding more RAM I guess I'm done primping and tweaking this classic machine.
    I'm really glad to see this new thread and that I'm not the only one with continuing affection for the 7811!
  9. TANWare
    Actually the power draw is not the TDP rating. The rating is just there as a guide for the cooling solution. It say's to the OEM that they need to be prepared for their systems cooling solution to transfer the TDP's rating of heat. You will find most CPU's in a class all have the same TDP independent of a wide variety of clock speeds. What the TDP envelope allows is for the CPU OEM to then tune the clock to the binned voltage so that the chip runs reliably within it heat allowance. This is why under voltage is so widely successful in overclocking a CPU.
    Now the newer iCores changed the game a bit in that they will try and run max core voltage to stay within a TDP even if just for short bursts and even on limited cores. In other words Intel took from the overclocking community and made it where the CPU will self overclock to get the best possible performance. This was the most recent, if not final, nail in AMD's coffin for the performance race.
  10. tallan
    Thanks for the correction. Would I be right, however, in assuming that the draw (and thus the heat, my real concern) of a CPU with a TDP of 45 would be greater than one of 28 in the same machine, say the 7811? With stock voltages and clocks, of course.
