7700HQ Power Limit Throttling
Discussion in '2015+ Alienware 13 / 15 / 17' started by koharatx, Jun 9, 2017.
  1. Vasudev
    Was the xtu service running in task Manager? Usually XTU and TS don't play nice if run simultaneously.
    Use HWINFO sensors to see PL1 and PL2 Limits set to 92W. XTU produces garbage values if TS modifies anything.
    Open services.msc and check if Xtu service is running or not?
  2. gschneider
    gschneider Notebook Evangelist
    Xtu was not running and is not running now.
    I could just uninstall XTU.
    if I set it in TS then i save and use turn on?
    Vasudev likes this.
  3. Vasudev
    Yes that should do it. If you don't press Turn ON TS won't work. In addition to that, uncheck speedstep and simply use Speedshift because it can ramp up/down the clocks in few nano seconds and faster than OS P states.
  4. Papusan
    High performance power plan will always have the clocks ramped up to max.
    Vasudev likes this.
  5. VICKYGAMEBOY
    VICKYGAMEBOY Notebook Deity
    im on a mission to revive my old m11x r2 baby alien.. small donations welcome :) curennt status : Display Working, battery working, Side I/O panel working, Keyboard Working, Other Small Components working, Adapter Working, bottom base ive fixed it myself with some paint job, RAM working, HDD working, Motherboard still on repair, some ICs on board need to be replaced which ive already submitted, Palmrest Assembly and LCD back cover panel needs to be replaced.. i bought it back in 2009-2010.. my first portable..
    Vasudev likes this.
  6. gschneider
    In the new creators update you don't get a high performance power plan.
    I have unchecked speedstep. Do I need to check speedshift-EPP or check speed shift within the TPL menu?
    I have tried whatever I can to get Throttlestop to set my TDP however it simply wont.
    Vasudev likes this.
  7. Vasudev
    yes. Might wanna ask @unclewebb about it. I was able to set TDP using TS.
  8. Papusan
    :rolleyes:Win X Crematory Fall Fail Update - Balanced (recommended)... Nope.
    Vasudev likes this.
  9. villahed94
    villahed94 Notebook Guru
    You can get the old profiles back but you have to disable "Modern Standby" via regedit.
    Maleko48 and Vasudev like this.
  10. Papusan
    Or pick what you want of power options in Windows Mobility Center.
    Yeah, The M$ Morons try to force us all over on Balanced power plans now. Because this power plan fits very well for the new hardware "Snapdragon chipsets" [​IMG] + their own utter Trash!!
    Windoze X desktop Tablet OS is redesigned for coming weaker hardware!! Microsoft: days of battery times with Windows laptops still this year? More of same ****y sadness...
    Here - Here - Here - Here:no: @Phoenix :rolleyes: Want the new throttlemonster from Micro$haft? As it fits Win X like a hand in glove. Or this one?
    Ashtrix and Vasudev like this.
