6700HQ not able to reach 3.5ghz, always stuck at 3.1ghz
Discussion in '2015+ Alienware 13 / 15 / 17' started by Claytankozmo, Mar 9, 2017.
  1. Rudamental
    Rudamental Newbie
  2. Papusan
    Papusan JOKEBOOKS = That sucks!! STAHP! Dont buy FILTH...
    Lower temp and lower power consumption is never a bad idea on a fully locked down chips. The CPU can run it's rated max Turbo Boost without throttle <if power consumption don't reach 45W limit>. Undervolt = lower heat - lower power consumption.
    duttyend and Vasudev like this.
  3. Rudamental
    Rudamental Newbie
    ok cool. I have done something and now it's stuck at 3.2Ghz no matter what.
    How do I reset ALL values?
  4. Papusan
    Exit ThrottleStop and delete ThrottleStop.ini file in TS FOLDER and then reboot. Take notice of what settings used <if> needed (sceenshoot). This will force ThrottleStop to create a new configuration file when it starts and it will read the current state of your CPU for its default values.
  5. Rudamental
    Rudamental Newbie
    I've done this however now even on a single thread bench it wont go above 3.2Ghz...
  6. Vasudev
    Vasudev Notebook Prophet
    Are you using Win 10 FCU (Fall creators update)
  7. Papusan
    ThrottleStop don't alter bios settings. Post pict of current TS settings. And WinCrap X is a trash OS. Newer the worse!!
    Donald@HIDevolution and Vasudev like this.
