6700HQ and AGA
Discussion in 'Alienware M15x' started by rockmedic109, Sep 28, 2018.
  1. rockmedic109
    rockmedic109 Notebook Enthusiast
    I've read that the I7 6700HQ will not use or work with more than 1920 Cuda Cores. Not that I would have any idea what a cuda core is.
    I am thinking of getting the AGA. Is there a fix for the 6700/Cuda Core issue?
    If there is no fix {which I assume is the case}, what would the effects be? Would a 1080 not work? Would it only use 1920 cores and effectively be a 1070? Would it just slow the 1080 down but still better than a 1070?
    Thank You
  2. Danishblunt
    Danishblunt Guest
    I don't see why there would be any limit at all.
  3. Grant B Gibson
    Grant B Gibson Notebook Deity
    Wrong thread, but to answer your question the actual bandwith would limit anything more than 1080, but you would still see benefit from it
  4. Danishblunt
    Danishblunt Guest
    I posted a literal firestrike benchmark from an AGA GTX 1080ti
    It didn't lose any performance. Still scored like a normal GTX 1080 TI.
    aga GTX 1080 ti:
    https://www.3dmark.com/fs/13249229
    GTX 1080 TI in desktop:
    https://www.3dmark.com/fs/12155032
  5. King of Interns
    King of Interns Simply a laptop enthusiast
    What is this thread to do with the M15x? Wrong location methinks....
