5920G cooling overhaul
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by triturbo, Apr 13, 2011.
  1. triturbo
    This project took me a year or so, where it could be done for couple of weeks, or a month at most :eek: It's running from quite some time now (you can see when the pictures were taken) and I'm pretty happy with it.
    Additional CPU, Wi-Fi and RAM heatsinks
    [​IMG] [​IMG]
    I've cut out all of the aluminum fins and made a copper ones (25) with custom profile, so it would be able to take a heatpipe. The heatpipe is from a friend's Gigabyte 8600GT Silent, I gave it a custom profile so it can fit under the bonnet :) All the fins are glued with Arctic Silver Thermal Adhesive, two at a time since I have to hold them down for about 5 minutes. Pretty tricky and time consuming job. It's not state of the art, but I don't care :p
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    I made holes on the thermal pad so it can fit perfectly on top of the GPU
    [​IMG] [​IMG]
    I've put some AKASA thermal tape on the heatpipe and it's ready
    [​IMG] [​IMG]
    Final setup
    Smile :)
    And the most important part - it does what it's meant to do :D
    -10ºC under FurMark :eek:
    There is still room for improvement, like adding a thin copper plate between the heatpipe and thermal pad, or cutting the entire GPU part and using a heatsink from another laptop... and so on, but I'll settle down for a while :)
    Credits should go to all the cooling overhaul topics around the forum (too many to list) :)
    Update 06 April 2012:
    Stage II + Turbo Upgrade :p
    I'll have to add some pics later, but the most important are here :)
    [​IMG] [​IMG]
    Added copper shim to the 2nd GPU heatsink, and also there's now 1,5mm thick 7W/mk Phobya XT thermal pad. Don't have exact measurements, since the room temp is different, but I guess it helps for 2~5ºC less.
    And now the most important cooling upgrade - the fan itself:
    Everything packed well, so no aluminum/plastic dust would get inside.
    Re-seating the third screw.
    After every good party, there's a pile of garbage :D
    Here are some before/after pics. I got both fans thanks to King of Interns, from his parted W860CU.
    There were some sacrifices in the process
    [​IMG] [​IMG]
    Thankfully, there's no audible difference before and after the intervention. Well to be completely honest, the left speaker probably lost a little deepness :eek: But just a little.
    Final setup
    [​IMG] [​IMG]
    It was quite of a grinding, indeed. Arctic Silver Thermal Adhesive used here as well.
    And finally, some back plate modifications. Stock mesh replaced with DEMCiflex mesh only.
    Update: 09/02/2014
    Stage III - SuperCooling
    - What do you mean SuperCooling?
    - Twin fans; triple heat-pipes and vapor chamber for the GPU; lots of copper aaaand a meter long pipe for water coooling :D
    That's it for now, thanks for reading :)
    Starlight5 likes this.
  2. King of Interns
    King of Interns Simply a laptop enthusiast
    Very good mod triturbo! Do I read 10C load temp for your 4670 or 10C drop in temp from previous temps??? Can't believe it lol
    Btw I am looking to loosen memory timings on the card or perhaps even perform a volt mod on the card during the coming months... will keep you posted :)
    Also nice one on the 8GB ram upgrade! I have a Intel X3380 in post on way to me as we speak as my next upgrade :D
  3. Meaker@Sager
    In your screenshot of the ram its only showing 4GB accessable in the windows task bar.
    Also Heatsinks on the wifi module?
    Otherwise nice.
    I'm a bit
  4. svl7
    svl7 T|I
    Did you bend the heatpipe? How? They're pretty fragile...
  5. King of Interns
    I think he bought a second heatpipe or perhaps had two separate heatpipes welded together. Probably the first rather than the latter though.
  6. triturbo
    LOL I wish it was the former, but sadly it's the latter :eek: Here's a screen
    What kind of soft you'll use for that task (loosen GPU mem timings)?
    A Xeon, nice :D I've just received a SLAQJ, but it wont post, it has a scratch on it, so I guess I'll have to return it and buy another one :(
    I don't know what you mean :p
    Why not?! After extensive use when I open the laptop they are pretty warm :)
    I thought as you, but I had to try it, otherwise it wont fit, and it's OK.
    As you said I bought a heatpipe and a second heatsink so I was able to work over one of them as much as I want (a year in that case :D ).
  7. King of Interns
    Ouch still 84C at 1.1V stock clocks?
    I don't want to make you feel bad but in crysis 2 I tried fans at full speed for a while at 750/985.5mhz for a laugh and after an hour temps on GPUz reported max 53C :eek: !!!
  8. triturbo
    Yeah, 5920G's cooling is poor but I love the damn thing :D
  9. King of Interns
    Indeed. I love mine too :) So what is your next upgrade going to be? Once I have installed the X3380 (once it arrives....) intend to upgrade wireless card perhaps and also go back to SSD.
    Are you planning to put an extreme chip in your acer?
  10. Meaker@Sager
