4k 65 Samsung TV used as monitor with Alienware 15 R5?
Discussion in '2015+ Alienware 13 / 15 / 17' started by flyboynm, Jul 12, 2020.
  1. flyboynm
    flyboynm Notebook Consultant
    I am wondering if I can push a 4k video signal from my laptop even though it only has the 1920x1080 screen. I have the i7-8750H and a 1060 video card.
    Will I be able to pull that off?
  2. etern4l
    etern4l Notebook Deity
    Depends on the lowest common HDMI port version across the devices. 2.1 can do 4k@120Hz (assuming the TV can support 120Hz 4K) , 2.0 @60Hz etc. Actually, not sure what HDMI version wouldn't we able to do 4K @ 60Hz.
  3. ssj92
    ssj92 Neutron Star
    Yes you can.
    HDMI 2.0 is supported on R5. I think since R4 or R3 you can do it.
    Worse case scenario is a active mDP to HDMI adapter.
    etern4l likes this.
