4940 upgrade problem.
Discussion in 'Alienware 18 and M18x' started by rband, Aug 3, 2020.
  1. rband
    rband Notebook Enthusiast
    I am trying to upgrade the cpu on my Viking and keep getting 4 beeps when ram is in channel A.
    If i remove the ram from those 2 slots the laptop boots fine.
    Reinsert the old 4700 cpu and both channels work , poss a bad cpu?
  2. senso
    senso Notebook Deity
    Check all pins for any dirt or slight bend, but it points to a dud CPU.
  3. rband
    Thanks for the reply , the CPU is what i suspect too.
  4. imest
    imest Notebook Consultant
    So I had this issue when I bought a MX4940 off ebay. I returned it and got a MX4940 from another seller and issue was resolved. I say it is the CPU.
    I bet you got my returned CPU lol, that would suck.
    edit: I just checked my history, it was MX4930 not a MX4940 that I had the issue with.
