4930mx / MSI 1070 / 32GB 2133Mhz DDR3 SODIMM / 17 R1 Motherboard + ETC
Discussion in 'Price Check Forum' started by TheReciever, Jan 20, 2020.
  1. TheReciever
    TheReciever D! For Dragon!
    Hey guys I need some advise about selling whats left of my 17 R1, as most of the storage had went to my desktop.
    I have the following.
    4700mq
    4980hq
    4930mx
    MSI 1070
    32GB 2133MhzCL11 DDR3 (4x8GB)
    Thanks!
  2. Maxware79
    Maxware79 Notebook Deity
    If you work out a price for the memory, I could be interested. If it's reasonably plug and play for the M18x.
    Also, I have an LCD assembly for a Ranger and some spare GPU's to test so a chassis with motherboard and CPU would be handy, if that's a possibility.
  3. TheReciever
    Should be plug and play for the most part, some people claimed otherwise but those may have been non xm chips
    I also have interposer cable for HDD, though its for the Ranger, not sure if those are compatible with the R2 though.
  4. Maxware79
    Unfortunately they went with a weird design on the M18x with a ribbon cable attached to three HDD interposer connectors. It’s a little too fragile
  5. Mastermind5200
    50-70
    120-160
    150-200+
    400min, 450-500+
    Unsure on the mem
  6. Rengsey R. H. Jr.
    Which is better between the two?
    The i7-4980HQ or the i7-4940MX ?
  7. Maxware79
    I'd say the MX since it's unlocked. I'm not sure if the HQ is. The HQ has a higher boost clock I think, which is good for people who don't want to overclock. I haven't looked up the specs but maybe the L3 cache is different.
  8. Maxware79
    No I was wrong. Same boost clock. The MX does have more L3 cache and it's unlocked
    Rengsey R. H. Jr. likes this.
  9. Mastermind5200
    If you can get it to work, easily the 4980HQ.
  10. TheReciever
    4980hq is the better chip, trick is getting it to work in the laptop, doesnt work in my Ranger but works on my t440p (minus mDP)
    Im considering selling it as I dont really Iris Pro for the t440p and have a spare 4700mq sitting around somewhere. I just use it for web surfing, writing, and a bit of work.
    The 4980hq is better mostly due to the L4 cache, and can be turbo'd to 4.6Ghz without mod.
