3k laptop for work? Stuck with choice :(
Discussion in 'What Notebook Should I Buy?' started by talionar, Jun 10, 2018.
  1. talionar
    talionar Newbie
    Hi there! Really stuck with the choice [​IMG] Will be glad to hear your advice!
    General Questions
    1) What is your budget?
    Max that I want to spend is 3k$ but it will be great to stay near 2300$.
    d. Mainstream; 15" - 16" screen
    e. Desktop Replacement; 17"+ screen
    Any place in EU/USA or with international shipping.
    No
    No
    I need multicore CPU for work, min 16gb of ram that I can upgrade to 32, great display (4k is better but I can afford to go fullHD on 15'') and GPU that can run up to 2 external 4k displays.
    Not a lot but when I travel I really need it to fit in common 15'' bag and I want to go max 3kg for 17'' and 2.5 for 15''.
    Not a lot. Maybe some Paladins, Firewatch like games e.t.c. Not AAA shooters in 4k)
    Doesn't matter a lot, but 2hrs is desirable so I can survive outage)
    It's ok without
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Anyway there is no chromebooks with my specs so I can just install Win on any device)
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Minimum FHD on 15'' or 3k+ on 17''
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Doesn't matter a lot - I have good workplace
    Build Quality and Design
    Style doesn't matter but it must feel sturdy
    Now) I can wait few months if some great will be released
    3yrs is good enough, more is better and I do not play games a lot so I think I can go with it for 5yrs
    Notebook Components
    SSD must have, 1TB in total is ok
    No
    So, it was a good table but my need in specific a bit. In short:
    1) Lightweight enough so it can fit common 15'' laptop bag compartment (in general I prefer to go max 3kg for 17'' or 2.5 for 15'' and 2.8 max thickness)
    2) It has good one display. I do not care about response time a lot, so it will be great to have 3k and good colors (I have to work a lot with colored text)), no awful backlight bleeding or other problems. I own now GT60 with 3k and reducing to fullHD is visible enough for me in text clarity, but I can afford fullHD on 15''.
    3) More cores are better and mainly I need great CPU rather than GPU) So I want to stick with 8th gen.
    4) From GPU I only need it to support up to 2 external 4k displays. In gaming I fully satisfied with my current GTX 780M
    5) RAM minimum 16gb upgradable to 32gb (I have 12Gb right now and in avg 700Mb free if I control what I run. Because if not all just crashes [​IMG] )
    6) Numpad will be huuuuge bonus for me
    7) 2.5 slot is plus too
    8) Battery life is not matters a lot (I have 2hrs max right now and it's ok for me)
    9) Good keyboard with some tangible travel (Dell XPS have just too small travel and feels uncomfortable. But, maybe it's just matter of habit?)
    And I ended up with this ones but each has it's own BUT:
    Asus GM501 (but not sure about display quality - I mean they rushed for 144hz and response time so colors can be bad and not sure about artifacts)
    Asus GU501 (GM501 with 1060 and worse display - not sure if it's really worse in terms of artifacts and colors? If they similar and have no other diffs except the raised bottom part in GM501 I will really go with this one)
    Asus GL703 (not sure about build quality, 17'' with fullHD only is too low)
    Dell XPS (8750H/3k version) (uncomfortable keyboard / no numpad but 3k display and good enough GPU for me)
    Also considered
    MSI GS65 (but heard a lot about OKish build quality)
    new Razer 15 (QC in Razer seems not so good so it's risky too and it's more expensive rather than alternatives)
    HP x360 (all is great except 8705g cpu)
    Aero 15/15x (seems like the build quality is Okish too and it has this webcam stuff and I use webcam 5 or 6 times per week so I can pay more for normal webcam placement like in GM501)
    Aorus X5/X7 v8 (seems like overpriced? but if someone will point to big positive diff between GM501 that I missed it will be great)
    I'm ok with fact that I need to replace thermalpads and to repaste to LM to make this stuff work without BSODs)
    Maybe I missed some great alternatives? Or what do you own/recommend from this based on my needs?
    Eager to hear your advice here!)
  2. Grant B Gibson
    Grant B Gibson Notebook Deity
    TBH I consider all of those trash (Max-Q + crappy cooling) except for the MSI's. I would personally go for Clevo desktop replacement, but those seem to be a tad expensive for your price range. Maybe the new MSI's?
  3. talionar
    talionar Newbie
    Hmm... Asus and Aorus are with full GTX. MSI, as I know, go with Max-Q and also non-IPS displays (seems like panels are somewhat near IPS but I can't compare them live). New MSI's - what models did you mean? Also, did you seen MSI GT60 (780M one) - how it's build quality for you?)
  4. Grant B Gibson
    The Aorus heavily throttles to the point below a Max-Q, I don't have much experience with the other models, but I would recommened one of the newer MSI's with a 8750h and a 1060 ( I don't know the model name
  5. talionar
    talionar Newbie
    Hmm. Do you think that liquid metal will not help with the throttle? Because they all hot as hell (it's just impossible to have such TDP in such thin laptop without problems) and anyway I think I will do LM and thermalpads replace even on XPS 15. So with LM and undervolting I think I can get them run cold enough to not throttle a lot.
    But thanks anyway) BTW new slim MSI is GS65 and it has some caveats too and I considered it also
  6. Grant B Gibson
    Sounds food to mee
  7. Danishblunt
    Danishblunt Notebook Prophet
    http://www.hidevolution.com/msi-gt63-8rf-titan-047.html
    Absolutely perfect. 94% NTFC, 120hz, great keyboard, good speakers, great thermals, perfect performance. It does everything you would ever want a notebook to do.15 inch as well and has a weight of 2.94KG.
  8. talionar
    talionar Newbie
    40 mm thickness and 3kg for 15'' dude : D This is no go for me)) Max that will be useful is 30mm (and this is really a lot already). Now I'm watching on workstations but seems like they overpriced because of other stuff that I do not need
  9. Danishblunt
    The issue here is that you want a 15inch notebook with CPU power, this is a problem because the thin and lights cannot sustain high CPU tasks over time, it simply cannot be done. The thin and light gaming notebooks are build to be able to play games on them which do not remotely stress the CPU as much as other tasks such as rendering.
    Kent T likes this.
  10. RampantGorilla
    RampantGorilla Notebook Deity
    Get the gigabyte aero 15 or the HP ZBook Studio 15". Both come with 4K panel options that cover 100% of Adobe RGB.
    talionar likes this.
