3D Vision on Clevo P370EM3 with GTX 1060 not working
Discussion in 'Sager and Clevo' started by D4RK, Apr 6, 2018.
  1. D4RK
    D4RK Notebook Enthusiast
    hello,
    i just upgraded my Clevo P370EM3 from a gtx 680m to a gtx 1060, its working fine with modded drivers but when ever i install the 3d vision driver after the installation was over i get the following error "this laptop's panel is not qualified for 3d vision". now 3d vision was working fine on 680m before the upgrade.
    any of u guys managed to get it running, or any ideas?
    thanks
  2. Meaker@Sager
    3d vision is not supported with another GPU. It will fail the support check.
  3. D4RK
    anyway to go around the check? or mod the driver so it sees the gpu as acceptable 1?
  4. sicily428
    sicily428 Donuts!! :)
    Is that an msi card?
  5. D4RK
    not really sure, i think its a clevo card, bought it from eurocom
  6. sicily428
    Black pcb------>msi card
    Green pcb----->eurocom card
    joluke likes this.
  7. D4RK
    the pcb is black, here is a picture. also why does it matter?
  8. yrekabakery
    yrekabakery Notebook Virtuoso
    Pretty sure 3D Vision isn't supported on internal panels since Maxwell.
  9. D4RK
    i figured its not supported by default, but i wanna know if there is any 1 around that.
  10. sicily428
    For a guide about mxm gpu upgrades :)
    May be @woodzstack @bennyg can kwow that issue
