3840qm Idle Temps M17XR4
Discussion in 'Alienware 17 and M17x' started by remedy1978, May 21, 2013.
  1. remedy1978
    remedy1978 Notebook Evangelist
    Wondering what everyone else is seeing for idle temps. I am getting around 50 to 55 degrees Celsius.
  2. ShirokenTech
    ShirokenTech Notebook Enthusiast
    My 3740QM idles around 50 so that sounds about right.
  3. Alienware-L_Porras
    That's normal, no need to worry about those temps... How are they during gaming sessions?
  4. remedy1978
    Ran 3Dmark06 last night. Processor reached 92 degrees Celsius. Seems pretty high.
  5. kakaroth1977
    kakaroth1977 Notebook Geek
    my same temp 50 56 °c in idle , 57 59 in web browsing but is very hot .
    In game 69-78°
  6. Quadzilla
    Quadzilla The eye is watching you
    Hmm i never reached 92 when i had it . Though i never ran 06 i ran Vantage and 3dmark 11 plenty of times and even with the stage 3 overclocking i think the highest temp i saw was 88 or 89 on the hottest core.
    You can always just loosen and re tighten the screws a little without repasting since they are so easily accessible. See if that helps improve your temps. It has MX-4 on it now.
    The 3840qm is a hot CPU and it would be hot even with a 3pipe heatsink in the M18x.
    I also always ran the machine elevated in the back and never using a cooler.
  7. .Cameron.
    .Cameron. Notebook Consultant
    I'd probably re-paste if I was seeing 90°C+.
  8. remedy1978
    Repasted with Prolimatech PK-1 and all is well. Max temps are now around 80 degrees Celsius.
  9. Alienware-Luis_Pardo
    Alienware-Luis_Pardo Guest
    That sounds more like it, I use it on a flat wooden surface with nothing to elevate the back and it never gets above 78-82 while gaming.
