[3820tray] Hardware Control PowerProfiles CPUMonitor
Discussion in 'Acer' started by inteks, Mar 16, 2011.
  1. inteks
    inteks Notebook Evangelist
    Features:
    -Overclocking CPU i5
    -Overclocking ATI with MSI Afterburner (has to be Installed and Unlocked)
    -Prevent Auto Graphicsswitching
    -Switch Graphics via Profile (you have to set Hotkeys in CCC for this)
    -Apply powerprofiles
    -Enable/Disable Devices and Services (powersaving)
    -Apply SystemTweaks
    -Change Display Resolution
    -Change Networkconfig,Proxy and Hosts file
    -Create Virtual Hotspot
    -Send Keyevents
    update v06:
    -profiles are now placed under "AppDataRoaming3820TgTray" (you have to move your actual profiles to this place)
    -cpu monitor added (optional see settings) (with process:kill/priority/limit cpu core)
    -more hotkeys available
    update v07:
    -renamed to "3820tray" (once again you have to move your profiles "AppDataRoaming3820tray")
    -limited CPU fancontrol turn CPU fan OFF while under a userdefined Temp (def. 70°C)
    -use this lib MSI Afterburner .NET Class Library - Guru3D.com Forums for ATI overclocking now
    update v09:
    -fixed some bugs
    -added full cpu fancontrol
    update v10:
    -fixed some bugs
    -added full ATI Fan Control !!!
    -added "Apply Profile on App"
    update v11:
    -fixed some bugs
    update v12:
    -you can use now the path to SetPLL in the SetFSB path Textbox ;)
    -minimized the writes to EC
    -some bugfixes
    update v14:
    -bugfixes in fancontrol
    -added tooltip for supported fsb's when using setpll
    update v15:
    -Fixed the ATI disabled but HOT problem !!! 3820tray set the ATI Fanspeed to auto if ATI temp == 0°C
    update v16:
    TDC TDP control for i5 turboboost added ;)
    update v17:
    -infowindow shows after delay
    -checks if mainboard JM31_CP , if not writing to EC controller is disabled (now you can use it for other notebooks too. i.e.4820...)
    -updated cpuspeed reading, now it reads turboboost speed correct
    update v18:
    create a desktopicon that applies a profile and start an application (with the icon of the application ;) )
    and some bugfixes . . .
    update v20:
    -infopanel is blue again
    -some bugfixes and performance optimizations
    -bugfix on saving profiles :eek:
    update v21:
    -fixed the netsh bug
    update v22:
    -removed fancontrol (still buggy)
    -added a tool to create batch files for the fanspeedmod ;-) (big thx to zsero)
    -added control of powerplay in profiles
    -added control of cpu max power
    update v24:
    -fanspeedmod batfiles are loadable now
    -lower TCP/TDP on HighTemp per Profile (see screenshot)
    -disable ATI powerplay per profile (see screenshot)
    -set Volume, mute/unmute per Profile
    -start/enable Bluetooth on Systemstart
    -Optional overwrite "Critical Batt Level" to below 5%
    -SystemBeep if remaining BatteryRuntime is lower 5minutes!
    update v25:
    -prevent automatic gpu switch should work with newest driver
    -trayinfo window is look is changable via systeminfo.css stylesheet
    -profile switching and systeminfo via browser (smartphone too ;) ) via port 3820 -> http://IpOffYourNote:3820
    BTW. i still have probs with Fancontrol still get ACPI errors in eventlog. and also i had a bluescreen !!! the fancontrol in 3820tray works but i cant recommend its use !!! :(
    better us this http://forum.notebookreview.com/ace...x-3820tg-mods-tweaks-only-15.html#post7383211 KBC mod from _InKr_ ! it works really well !!!!
    :D
    USE OF THIS SOFTWARE AT YOUR OWN RISK !!!!
    v18 is a renamed RAR pls change extension after downloading ;)
  2. inteks
    HOWTO:
    Get SetFSB:
    SetFSB_HomePage
    OR
    Get SetPLL:
    http://forum.notebookreview.com/ali...-use-setpll-overclock-your-r2-over-166-a.html
    Get MSI Afterburner:
    Afterburner 2.1.0 download from Guru3D.com
    HOW TO: Enable UNOFFICIAL overclocking mode in MSI AfterBurner
    Set MSI Afterburner to "start minimized" under Options.
    3820tray start it automaticly on Overclocking ATI and Kill it on switching to INTEL
    to Switch Graphics ATI/Intel Via Profile you have to Configure Hotkeys in Catalyst Controlpanel:
    1. Open Catalyst Controlpanel
    2. On The TopRight Corner in the Options Dropdown Select Hotkeys ->HotkeysManager
    3. Select Hotkeys for HD 5650
    4. For ATI set Hotkey to Ctrl+Shift+Alt+A
    5. For Intel set Hotkey to Ctrl+Shift+Alt+E
    now 3820tray can switch the Graphics via Profile for you
    to add Devices and Services you want control via Profile:
    1. right click on 3820tray icon -> select options
    2. in deviceslistview rightclick -> select AddDevice
    3. check the devices you want to control and click "ok"
    to create a profile
    1. click on the devices you want to turn off until they are "red"
    2. i.e. select "Overclocking" and set it to 150MHz
    3. i.e. select "Execute Programm" and set it to "C:\Programms\EA\Need for Speed\NFS.exe"
    4. set "Name:" to "Play NFS"
    5. click "Save as Profile"
    6. close the optionsdialog
    7. select "Play NFS" from icon Contextmenue
    3820tray overclocks now your CPU and then start NFS ;)
    to apply some settings on the fly
    1. click on the first devices (ie. webcam) you want to turn off until it is "red"
    2. click on the second devices (ie. Wifi) you want to turn off until it is "red"
    3. set "Apply GFX Powersaving" to "Enable Powermanagment" and "MaxBattery"
    4. click "Just Apply"
    3820tray only apply the selected options without creating a profile
    to create a desktopicon
    1.create your profile...
    2.select "Execute Programm" and set it to i.e. "C:\Programms\EA\Need for Speed\NFS.exe"
    3.click "createShortcut".
    3820tray creates a desktopicon that executes your profile and then start your app. it use the icon from the application
    more to come . . .
  3. KingRaptor
    KingRaptor Notebook Evangelist
    Any chance for this program to work at least partially with a 4820TG?
    I don't need it to overclock or anything.
    The only functionality I really want is to disable automatic switching of GPU. I want to run on the Intel HD all the time (even when I'm plugged in.) I will manually switch to the ATI card if I need it (rare.)
    Awesome program by the way. It's just behaving a bit weird since I don't have a 3820TG
  4. Just_a_Nick
    Just_a_Nick Notebook Deity
    The anti switch option should also work on the 4820.
  5. KingRaptor
    Awesome, just figured out how to add devices in 3820tray. I just disabled the Radeon and installed Intel HD drivers.
  6. inteks
    update v09:
    -fixed some bugs
  7. KingRaptor
    My download keeps on freezing around 63kb. Is there an external mirror?
  8. welle
    welle Notebook Enthusiast
    I am thrilled by your tool. Hope to see soon all new developements.
    Question: Temp read by the tool is higher (10-15°C) as what I get from other tools such Core Temp. Is this a bug, or are your tool's settings better for 3820 as the others?
    Welle
  9. D_Nyholm
    D_Nyholm Notebook Enthusiast
    trying to use this with a 4820tg and I am able to get the program running inthe tray, but when i try to open the program by double clicking, I get an error and the program shuts down :(
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: The system cannot find the file specified
    at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    at _3820tray.NetSh.Execute(String Command) in C:\Users\inteks\Projects\3820Tray\NetSh.cs:line 28
    at _3820tray.NetSh.get_Interfaces() in C:\Users\inteks\Projects\3820Tray\NetSh.cs:line 257
    at _3820tray.options..ctor() in C:\Users\inteks\Projects\3820Tray\options.cs:line 54
    at _3820tray.Program.OnOptions(Object sender, EventArgs e) in C:\Users\inteks\Projects\3820Tray\Program.cs:line 799
    at System.Windows.Forms.NotifyIcon.OnDoubleClick(EventArgs e)
    at System.Windows.Forms.NotifyIcon.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.NotifyIcon.WndProc(Message& msg)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  10. inteks
    do you remove your netsh.exe ???
