32bit Antiirus on 64bit Vista
Discussion in 'Security and Anti-Virus Software' started by morgan-X65, Oct 20, 2007.
  1. frazell
    frazell Notebook Deity
    It all depends on what the virus does on whether or not it would affect a Vista 64bit installation... It would have a harder time infecting the Kernal on a 64bit installation and patching memory, but it can still leverage holes in programs that are 32bit (Depending on the exploit type of course)...
    Also, you can run 32bit AV processes in 64bit Vista and they will be treated like any other 32bit process, but in order for the AV program to patch the Kernal and offer very low level protection it will need to be 64bit... As only Vista 64 has "PatchGuard"...
  2. Fade To Black
    Fade To Black The Bad Ass
    Yes, it can, but not all the viruses can affect as much as they can do it on a x86 system.
  3. Fade To Black
    It will work on x64 OS. These work: AVG, Avast, Kaspersky, NOD32, Panda, Symantec Anti-Virus (not sure about Norton AV). Possibly others, but can't remember now. All tested by me, except for Panda.
  4. Les
    Les Not associated with NotebookReview in any way
    The question is though... How susceptible is 64Bit OS to viruses presently. Can a normal virus penetrated and plant itself in the 64bit system through 32 bit applications?
    Am I safe to play unprotected? lol
    Mind you, I just checked my AVG records and it doesnt appear anything is hitting.
  5. Fade To Black
    Well, trust me one this scenario:
    1. You get a virus that deletes any file with a specific extension.
    2. That virus doesn't need any kernel hooking (something where PatchGuard would have something to say)
    3. It will delete whatever it wants.
    It's just that simple.
    It all depends on what the virus needs in order to really work and stay there and **** up whatever it may want. However, I have Vista Ultimate x64 only with Windows Firewall, a hosts file and SpywareBlaster (which doesn't have a resident scanner, only some sort of hosts file) and I don't have any viruses.
