32bit Antiirus on 64bit Vista
Discussion in 'Security and Anti-Virus Software' started by morgan-X65, Oct 20, 2007.
  1. morgan-X65
    morgan-X65 Notebook Consultant
    Will a 32 bit antivirus program like Symantec client security work on a 64 bit version of vista?
  2. bigspin
    bigspin My Kind Of Place
    No .You'll need 64Bit version AV program.
  3. Les
    Les Not associated with NotebookReview in any way
    Wait...I run 64bit with 32bit AVG. Are you saying it does no good? Is it not possible for a virus to enter and affect 32bit programs through x86 within 64bit Vista?
    I use 32bit browser because video works easily. Is it not possible to get through by this method?
  4. morgan-X65
    Ok so do NOD32 have a 64 bit compatible version?, as this seems popular if i need to buy a new one.
  5. Charles P. Jefferies
    I would think NOD32 would work fine on Vista x64 - it works fine on Vista (had it installed on all of my Vista machines before I formatted them and installed XP) and I have it running on my XP x64 machine.
    You can download a trial version if it.
  6. Fade To Black
    Fade To Black The Bad Ass
    32 bit security software don't work on x64 OS, but if it's a 32 bit process doesn't necessarily mean that it will not work. AVG now works on 64 bit OS.
  7. morgan-X65
    So is there someone who has actually put nod32 on a vista 64 bit OS?
  8. Les
    My question is still the same...
    Can a 32bit virus hit a 64 bit system through 32 bit programs such as IE?
  9. bigspin
    Flam technically it can't be happen,Because 64Bit windows kernel is different than 32Bit,but we can't 100% sure about that!
    I heard 14 Years old virus affect vista 32Bit. We all know 14 years ago virus writers never heard about 32 Bit system & they never target Vista ,Windows is not so safe like MS state.
  10. planet_vikram
    planet_vikram Notebook Evangelist
    I have put....It works perfectly fine !!
