32-bit xp in a 64-bit laptop
Discussion in 'Windows OS and Software' started by magn3t0, Jan 31, 2008.
  1. magn3t0
    magn3t0 Notebook Consultant
    I’m not technically inclined with regards in software-hardware compatibility, so could someone please answer this question for me. Could I install a windows xp 32-bit in my compaq laptop which is a mobile turion 64 without any problem? Thanks
  2. Arki
    Arki Super Moderator
    Yes, it'll do just fine.
  3. Duct Tape Dude
    Duct Tape Dude Duct Tape Dude
    Yes, 32-bit computing is backwards compatible with 64-bit processors, with very little if any performance loss. This is much like the jump from 16 to 32 bit computing years ago.
    A 32-bit version of windows also means you can run the much older 16-bit programs without a hitch.
  4. Fade To Black
    Fade To Black The Bad Ass
    It's not like that jump. It's like jumping from 32 to 16. Why would you do that?
  5. crash
    crash NBR Assassin Super Moderator
    Here is a basic guide to 64-bit.
  6. lordvader
    lordvader Notebook Evangelist
    Is the new AW m17x a 32-bit OR a 64-bit laptop ?
  7. goofball
    goofball Notebook Deity
    What do you mean?
    The AW m17x will have an x64 capable processor. Is that what you are asking?
  8. lordvader
    yes will it have x64 capable processor ?
  9. goofball
    Yes, core 2 duo is x64 capable.
  10. lordvader
    thank you :)
